Results 1 to 7 of 7
Thread: conceerned about pH and TA
    Kathe's Avatar
    Jun 2015
    Saline, MI
    46
    I'm a little concerned about my pH and TA. We just topped off our pool to begin the season. My numbers are:
    FC .8 I'm adding chlorine
    pH 7.7
    TA 105
    CH 149
    CYA 19 I'm adding 3# of CYA
    I have a vinyl above ground pool. Water was nice and clear when we took tarp off. Water is at 70 degrees.
    Above ground 27' round, 17,000 gal., 52" high; vinyl liner; TropiCal 96,000BTU Heat pump; Integrity A Frame Ladder; Solar Blanket, Aqua Cover by PolyAir Corp, thermotex clear, 5 yr. warranty, cartridge filter., Clear Bay Cartridge CBA2-10043 (two to switch out when cleaning); New pool as of 6/1/15.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Re: conceerned about pH and TA
    Your pH and TA numbers are fine for the moment. Your TA might be a little high but when your pH goes over 7.8 and you add acid to bring it down, your TA will come down with it
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Kathe's Avatar
    Jun 2015
    Saline, MI
    46
    Thank you!
    Donldson's Avatar
    NW Ohio
    2,892
    Where are you getting your test results?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Kathe's Avatar
    Jun 2015
    Saline, MI
    46
    I take my water sample to a company near me who will test it for me.
    38,274
    Uh oh, we have found that pool store testing is notoriously inaccurate and not repeatable.
    If you want to be sure and take control, I highly urge you to invest in one of the recommended test kits.
    Kathe's Avatar
    Jun 2015
    Saline, MI
    46
    I appreciate the feedback. I will probably get a kit one of these days. I made it through my first summer without one. Maybe just beginner's luck!
