Thread: Screwed up a return!
    Aug 2013
    Hilton Head, SC
    133
    Unhappy Screwed up a return!
    OK, trying to add a "water feature" to our pool, I snapped off one of the return outlets. I had taken off the threaded nozzle cover, and putting it back on it broke apart.
    Pool was built in 1991, and the heat here in South Carolina I'm sure takes a tool on this PVC (if it's PVC). Name on front of the threaded part says "Pac-Fab, Inc." It looks to be about 1 1/2" diameter. There is a remaining portion of it still glued into the return piping, maybe 1/2".
    Questions:
    Can I find a replacement part for this? I googled Pac-Fab and found only replacement parts for filters, etc.
    Do I need to drain the pool below the return to remove the remainder of the outlet part? Can I repair it "under water?"
    Once I get the remainder out, is there a newer return type that I can install? Maybe one that threads male into female, versus female onto male?
    I've added a picture of the return in case that helps...
    thanks!
    ed marshall
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,383
    Re: Screwed up a return!
    Is the part remaining in the pool wall threaded? Did you look at these? Directional Insider Swimming Pool Outlet - White - Pentair 542002 | Ace Pools
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Does one of these look like it? Wall, Return and Eyeball Fittings.
    Aug 2013
    Hilton Head, SC
    133
    The first one looks like it. It's definitely a slip fitting. Glued in. Some portions of it are still in the return pipe
    Aug 2013
    Hilton Head, SC
    133
    Ok what's the best way to remove the pieces of the nozzle that are glued in the return pipe? Drain the water below the pipe and use my dremel? Is there a special solvent for this?
    Aug 2013
    Hilton Head, SC
    133
    I've searched all these forums, and the return repairs I've found deal with threaded nozzles. My nozzle was glued in back in 1991. The only thing I can think to do is drain the water to just below the pipe and use my dremel to slowly file away the pieces remaining that are glued in. Yes/no?
