Results 1 to 11 of 11
Thread: New liner starting over need help with proper chemicals
    Apr 2016
    Langhorne,pa
    9
    I just had new liner installed was told that old one had signs of too much chlorine, so I'm here to learn what to do . I just filled pool with water (public water not well water) and test results are , CL 0,PH 7.5,TA 70,CH 0,CYA 0, so was wondering what to start with I would like to use bleach instead of tablets which I think was my problem of over chlorinating , any help would be appreciated thank you
    13,500 ,AG,jacuzzi s15LR9-6 pump,jacuzzi AV 60 DE filter,installed 2005,TF 100 test kit,Pool rover cleaning robot , new liner 4/2016
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: New liner starting over need help with proper chemicals
    How old was the old liner and was it originally yours or did you buy house with a pool already installed? Added properly ---slowly in front of a return with pump running should cause no liner issues. The FC level could have been held too high for the CYA level. LOW PH can causes more issues with a liner over time. Take CYA to 30 assuming no SWG and dose FC to 5 per Pool School and see how it acts. Welcome to the forum.
    30,403
    Welcome to the forum. Woody has you covered. Those numbers are really pretty good but you need to get the chlorine and CYA in their right away.
    And, yes, liquid chlorine (bleach), is the finest chlorine you can use so we encourage everyone to use it. Asl lot's of questions and we'll all help keep your pool crystal clear
    Apr 2016
    Langhorne,pa
    9
    Quote Originally Posted by woodyp View Post
    Thank you , we had the pool installed in 2005 liner was 10 years old what do you recommend to get the cya level up and the chlorine I know that trichlor has cya in it how should I proceed thank you for your help
    Apr 2010
    East Texas
    9,569
    Pretty hard to beat cya "conditioner" and plain old bleach, 8.25% from Walmart.
    Apr 2016
    Langhorne,pa
    9
    Sent from my XT1030 using Tapatalk
    Thank you will do I'll get back with readings
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Painterjohn View Post
    Trichlor pucks take a while to dissolve, and they're very acidic. If you look at Poolmath, down at the bottom, you can use Effects of Adding Chemicals to see just what an 8 oz puck will do to your water chemistry. Do you really want to be juggling FC, CYA, pH, and ultimately TA simultaneously? Better to use separate CYA and bleach.
    Pool School - Recommended Pool Chemicals tells you what does what and how to add it.
    Pool School - PoolMath will tell you how top use poolmath to figure out how much to add.
    Apr 2016
    Langhorne,pa
    9
    I have a question about combined chlorine pool is clear no problems just no combined chlorine do I need it if so how do I raise it my readings are
    Fc 5
    ta 100
    ph 7.8
    cya 40
    Cc o
    thank you for the help
    Richard320's Avatar
    Jan 2010
    18,967
    Fc 5
    ta 100
    ph 7.8
    cya 40
    Cc o
    Combined Chlorine is the bad stuff. Having no CC is a good thing.
    Apr 2016
    Langhorne,pa
    9
    Thank you then I'm on the right track
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Fc 5
    ta 100
    ph 7.8
    cya 40
    Cc o
    Have you looked at POOL SCHOOL yet? Button at the top right of your screen. I think you need to read the ABC's of Pool Water Chemistry, then click on table of contents.
    You WANT the CC to be zero....
