Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Opening Up Pool for Summer - CYA
    Jul 2015
    Livingston, Louisiana
    174
    Hello Everyone,
    I am opening pool for the season and just tested levels, which are as follows:
    pH = 7.8
    CL = .5 ppm
    FC = 1
    CC = 0
    CH = 50 ppm
    TA = 65
    CYA = 15
    I know first thing I have to do is add stabilizer (pool math suggests 50 oz to bring up t 40). Then once that is up should I just add chlorine according to the chart or should I do a SLAM just to make sure?
    mkaklis
    27' x 52" AG vinyl, 16,000 gal, Pleatco PAP100 Cartridge Filter, 1.5 HP pump, TK100
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Opening Up Pool for Summer - CYA
    I'd lower my PH a bit first and raise the FC level for your target of CYA. Why do you think you need to SLAM?
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Get the CYA in there first. Then immediately get enough liquid bleach in there so that you have 5 ppm of FC (so that the normal daily drop never goes below 3) and monitor daily for a bit. If you don't have algae apparent you'll discover any problems developing by daily FC/CC checks. If your CCs go up you'll know something is in the water to deal with.
    Use this guide: Pool School - Chlorine / CYA Chart
    Jul 2015
    174
    Quote Originally Posted by woodyp View Post
    OK, so according to pool math 10 oz of MA will lower the pH to 7.5; I will do that first, then add stabilizer in sock and immediately add bleach to bring to 4 ppm. I only figured on slamming because there was some algae at bottom, but I put in some bleach a couple days ago and it seemed to clear up. Guess I should wait until I have levels in line and then see if there is a problem before slamming. Thanks.
    Quote Originally Posted by YippeeSkippy View Post
    OK, thanks. I have used the chlorine / cya chart so will continue to do that once the stabilizer and bleach are in.
    mkaklis
    Jan 2012
    7,338
    Quote Originally Posted by mkaklis View Post
    You mentioned getting your CYA level to 40. Based on the CYA/Chlorine Chart your absolute minimum FC level is 3. Pools have a normal daily chlorine loss usually about 2-3ppm. If you only bring your FC to 4 as you later mention, your FC will drop down below your absolute minimum of 3 and that could open the door to let algae in. I would suggest you aim for 5 so that if you lose 2ppm daily you'll still have 3ppm available. If you test and find you're down lower, say 2ppm, then you just need to redose to 5.5 or 6ppm daily to cover the loss. Capisce??
    Jul 2015
    174
    I understand and will aim for 5 and adjust accordingly as you suggest. Thank you.
    mkaklis
    Jul 2015
    174
    I do know that I need to get chlorine in as soon as possible because I fear getting an algae growth with it so low right now.
    mkaklis
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,508
    You seem to be on the right track! Good job! Keep your levels inline with the charts for your kind of pool. Let us know how your water looks.
    Kim
    Jul 2015
    174
    Thanks kimkats. I think I am finally learning thanks to people like you.
    mkaklis
    Jul 2015
    174
    Just one question. When I put the ma, stabilizer and bleach in, how long should I wait between each or can I put all in at the same time. I was thinking to put the ma in, test in about an hour and if oH is low enough put stabilizer in sock to start dissolving, then put in bleach tonight. Or can I put the bleach in the same time as the stabilizer?
    mkaklis
    Jul 2015
    174
    Oops pH not oH. lol
    mkaklis
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Sent from my VS990 using Tapatalk
    Add acid or bleach, your choice. Then fuss around with the CYA and the sock. By the time that is done, you're ready for acid or bleach, whichever is left. Total time, half an hour, maybe.
    Jul 2015
    174
    Great, I think I did right then. I put in the acid, waited about r5 min., then put stabilizer in sock, waited about 15 min and then added bleach. Have a dance review to attend but will test everything again later this afternoon. Thank you.
    mkaklis
    Jul 2015
    174
    Oops that is 45 min wait after the acid 😄
    mkaklis
    Jul 2015
    174
    Guess I am on the right track given my levels this moring:
    pH = 7.2
    CL = 5
    FC = 4
    CC = .5
    CH = 75 (I know I don't need this with vinyl but take it every now and then)
    TA = 70
    CYA = 50 (still have a bit left yet in sock dissolving so will take again when done)
    I guess at some point I will have to increase the pH a bit if it still shows 7.2 by adding a bit of borax or if TA is still low I will add baking soda, which if I am not mistaken, increase the pH a bit, right?
    mkaklis
    Jun 2014
    15,121
    Your TA is fine at 70. I'd just leave it alone right now and raise the pH (borax or soda ash) to about 7.5. Keep a close eye on your FC though as your FC target during the day is currently 6 (based on a CYA of 50). If your CYA creeps-up more, the FC will need to be higher as well. Never go below an FC of 4. Hope that helps.
    Jul 2015
    174
    Quote Originally Posted by Texas Splash View Post
    Yes that does help. Thanks.
    mkaklis
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Yep, good plan. Numbers look good. How does the water look?
    Jul 2015
    174
    Water looks good - was a little on the cloudy side but seems to be clearing more and more.
    mkaklis
  20. Back To Top    #20
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I would perform an OCLT if you saw algae the other day and still have a bit of cloudiness. A SLAM may be needed after all.
