Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Major problems
    May 2015
    TN
    312
    Major problems
    We just took the cover off of our pool and the sides in the deep end are caved it towards the bottom of the pool. In some places the liner is folded ovr itself. I am at a loss for words. We haven't had a bunch of rain this winter either. ANYONE HAD THIS PROBLEM??? I am so sick.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,596
    Re: Major problems
    I'm sure we'd all like to see some pics of the problem. Is it just the vinyl that the "side is caved in" on? Hopefully just water behind the liner. Is the liner pulled off the top edges any where?
    May 2015
    TN
    312
    Re: Major problems
    The liner was pulled from the top in a few places previously. The liner looks like fat belly rolls hanging over each other. You can also see jagged rock edges behind the liner.
    I can't get the pics to accurately show what has happened.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Major problems
    We will take any pics even if you don't think they will tell us much. With pictures we can often crowdsource some ideas for you.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,467
    Re: Major problems
    I have a sad for you Share pics and hopefully someone will have some ideas.
    Kim
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Major problems
    Ground doesn't shift for no reason. There could have been groundwater coming from higher elevations, a broken sewer or water main, mild earthquake, something had to cause the earth to collapse in that area. Have you noticed any sink holes in your yard? Check and see if your homeowner's insurance will cover any repairs. Please post your pictures even if you think they don't show anything, it will still help us try to figure out what happened.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    TN
    312
    Re: Major problems
    May 2015
    TN
    312
    Re: Major problems
    I spoke with the guy that installed the pool 15 yrs ago. He said it sounded like a groundwater issue, but wouldn't be for sure until he looked on Monday.
    Here is what I do know...
    When it was closed for the winter, the water level was just at the jets. Now the water is at the bottom of the steps. I told the pool installer this and he said the groundwater can come up and purge your water out of the pool. He also said the water should never go below the skimmers. I am not so sure on that one...
    Also, for kickers, our wonderful neighbors did shoot some exploding targets literally about 50-60 yards from my pool. I am highly suspicious of this... and very peed off.
    There are "fat roll" looking areas at the very end on the pool light end. On the sides you can see rocks purging through the liner.
    Jul 2009
    Houston, Texas
    9,379
    Re: Major problems
    Ok, the bulges you see at the bottom may not be rocks. It could just be that there is water behind the liner. You might have a leak that is allowing water behind the liner. The pool guy should be able to give you a better idea what is going on. Out of curiosity, have you tried nudging the bulges with a pool net? If it has a little give to it then it is water. You can try very gently nudging it with the pool net so you don't damage the liner.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    TN
    312
    Re: Major problems
    Quote Originally Posted by zea3 View Post
    No, they don't give. Hard. You can tell in other places on the wall that there are very jagged rocks pushing through.
    Jul 2012
    Tallahassee, FL
    30,467
    Re: Major problems
    Okay so what does the ground look like around that area of the pool? Use care when walking on it just in case.
    Trying to figure out this puzzle
    Kim
    May 2015
    TN
    312
    Re: Major problems
    It looks as it has looked. The concrete area in between the pool and sunroom which runs the length of the pool has dropped about 2-3inches. It has not changed in a while.
    May 2015
    TN
    312
    Re: Major problems
    And the water level is just below my light in the pool. I had a other post on my light. It is awful. Seal is deterioted all around it. Is it possible water got in around it and caused this? Even on the long sides of the deep end?
    May 2015
    TN
    312
    Re: Major problems
    And the water level is just below my light in the pool. I had a other post on my light. It is awful. Seal is deterioted all around it. Is it possible water got in around it and caused this? Even on the long sides of the deep end?[URL=http://s1129.photobucket.com/user/
    [COLOR="silver"]- - - Updated - - -[/COLOR]
    Oct 2014
    Sacramento, CA
    72
    Re: Major problems
    Down here in are area most vinyl pools have cinder block walls maybe they cell down or broke for some odd reason can't say i have ever seen that happen but its possible
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Apr 2016
    Cleveland, ohio
    7
    Re: Major problems
    I wonder if you couldn't take out a small section of the deck and get a mini to dig down below the bulge hopefully releasing the pressure and then add dirt. do you know what kind of dirt is there? Sand? topsoil or clay?
    Just my 2 cents.
    May 2015
    TN
    312
    Re: Major problems
    Pics posted
    May 2015
    TN
    312
    Re: Major problems
    If there was only a leak and water behind the liner it couldn't cause the concrete to bust out enough to let soil/rocks through, right? It is strange that the water level is just at the bottom of the light but I can't figure out what the jagged pieces are poking through the liner. It should just be finished concrete under the liner, right?
    May 2015
    TN
    312
    Re: Major problems
    Ok, is anyone still here? Lol. I posted pics and now no one will reply
  20. Back To Top    #20
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Major problems
    Perhaps more pictures might help? Like standing back so you can see the perimeter of the pool, etc. (if you have troubling posting more, use an image hosting site such as Photobucket and copy and paste the IMG code in the reply.)
