Results 1 to 9 of 9
Thread: Scrub walls on plaster pool to lower CYA.....
    Apr 2016
    Eagle, ID
    3
    My cyanuric acid reading was very high this opening. Was advised to drain and refill (3/4 drain anyway) to dilute the CYA. First reading after refill was acceptable (60) so I brought all other things into balance. Second reading after refill was very high (130) and third reading 2 days later was off the charts again. After lots of checking with others, it was suggested that I need to brush the walls and flush with water continually when draining the pool. Apparently the CYA will attack to the plaster and reintroduce itself when the pool is refilled. Anyone have experience with this? I am about to go about it again and want to get the best result possible as water is quite spendy. Pool is 25,000 gal., inground concrete/plaster, 15x30.
    Phil
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Scrub walls on plaster pool to lower CYA.....
    I've never heard of such. Even if it did a tiny bit, it certainly wouldn't double the reading as it is thoroughly mixed in with the pool water. There is no CYA in tap water btw. Pool stores are notorious for their BAD testing of CYA in particular. Do you have one of our recommended test kits, or how was this tested? Welcome to the forum.
    I have heard people make the claim that cyanuric attaches to plaster but I'm doubtful that it actually happens to any large degree.
    With high levels of CYA, the acid actually leaves the water and attaches itself to the plaster.
    Acid Watch| Pool Spa News | Bond Financing, Water, Water Conservation, Water Quality, Chemicals, Arch Chemicals.
    Support the site
    Apr 2016
    Eagle, ID
    3
    Quote Originally Posted by woodyp View Post
    The pool store tested the water with an electronic test unit and verified with test strips. I've been dealing with these guys for 15 years without any issues. I don't have one of the test kits your mention. Which kit in particular would you recommend?
    Apr 2010
    East Texas
    9,581
    That should tell you how sure they are of their "electronic " testing that they would even consider verifying by using an even less reliable test strip. Get the TF-100 and don't look back.
    The TF100 kit is the preferred kit. See link in my signature.
    Also, if they were giving you good advice, your cyanuric acid level wouldn't be so high.
    Support the site
    Isaac-1's Avatar
    SW Louisiana
    6,711
    To us that sort of sounds like predicting the weather by observing tree leaves and confirming with a magic 8 ball, the first may have some basis in science, the second much less so. While there are some electronic test systems that may provide meaningful test results the key to any of them is proper operation and calibration, a thing that is often poorly lacking in pool stores often operated by seasonal employees.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Phil, are you sure about your volume calculation?
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Apr 2016
    Eagle, ID
    3
    Quote Originally Posted by Helen203 View Post
    Pool is 25K+-. I am only able to drain 2/3 - 3/4 due to water table. I am redoing and hope dilution does the trick. Repeat if necessary.
