Thread: Intex SWG
    May 2015
    Ohio
    13
    Intex SWG
    I just bought the Intex 120V Krystal Clear Saltwater System CG-28669 with E.C.O. (Electrocatalytic Oxidation)
    for my above ground pool..I've been reading about people removing or disconnecting the copper cells.
    Does this model even have this? My wife and daughter are blondes and they'd kill me if green hair happened
    Allure52 24' round AGP 13,000g/sand filter/Intex SWG....Taylor K2006
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Intex SWG
    When I first found TFP back in 2012, there was a lot of talk about doing this. I haven't seen it mentioned in a long time. Hopefully someone will know.....
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Intex SWG
    I can't tell for sure but that appears to be an ozone system and not a "mineral" copper system. I think you are safe with it. We can't have you getting killed over some green hair!
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Re: Intex SWG
    I owned the ECO 7110 & 8110 units don't think you will run into that problem.
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Jun 2015
    Stockholm, Sweden
    250
    Re: Intex SWG
    The ECO models do not have the copper plates
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    May 2015
    Ohio
    13
    Re: Intex SWG
    Thanks for the replies
