Thread: testing at shock level.. help please!
    May 2015
    Mechanicsville, Va
    12
    I can't seem to find how to test chlorine when up to shock level (16+). I have the TFT test kit, isn't there a way to test and not use so much R-0871. I see some mention of it around but can't find the exact procedure anywhere.
    16x32 In-ground 22,000 gallon vinyl liner pool. 1HP Hayward Super Pump. Sand filter.
    Jun 2014
    15,059
    Re: testing at shock level.. help please!
    Here's a couple alternatives:
    5ml sample, multiply drop count by 1 (used to save on reagent; not as precise)
    10ml sample, multiply drop count by .5 (standard method) - most common
    May 2015
    Mechanicsville, Va
    12
    ok, it was the 5ml one I wasn't sure about. thank you!
