Thread: Losing water
    Apr 2016
    Murfreesboro, TN (Middle TN)
    103
    Losing water
    Hey guys. I've noticed I'm losing water during my slam which is most likely from opening filter housing to clean. Assuming this is not the issue, how much water is normal to lose from evaporation?
    27' above ground, 17500 gallons, Cartridge filter Hayward SW1000z4, A.O. Smith Pump SP1515Z1BC 70 GPM, Test kit Taylor TF-100
    Murfreesboro, TN
    Jun 2014
    15,192
    Re: Losing water
    A few variable there depending upon amount of sunlight, wind, surface area exposed, etc. In your pool I would hope this time of year no more than about a 1/4" or less - ballpark. That's the best I am at math on a Saturday morning.
    Apr 2016
    103
    Re: Losing water
    Thanks Texas. I will top off again after I finish slam and watch it. I went from mid skimmer down to about an inch into skimmer which seems excessive, but a lot comes out of that filter when I dump it.
    Murfreesboro, TN
