Thread: Pool stain identification
    Apr 2016
    Loxahatchee, FL
    12
    Good morning!
    Here are my water test results from yesterday:
    FC 4.5
    CC 0.5
    CH 675
    TA 210
    I also just purchased the speed stirrer so I can't wait for that!
    I have some stains on the plaster and I was hoping someone could help me identify and hopefully fix.
    The one on the top is dark, almost green in color and the one on the bottom I think might be calcium.
    Any idea on how I can get rid of these?
    18500 gallon oval pool. Filter: Hayward cartridge filter. Model: C12002. Pump: Hayward 1 speed (I think) 1.5hp Max-Flo XL Pump. Model: C48D43AO4. TFT100 test kit.
    Jun 2014
    15,259
    Re: Pool stain identification
    Good morning. I didn't see your pH reading above, but here are some basic rules for ID'ing stains:
    - Hold a chlorine tablet against the stain; if it goes away, it is organic (i.e. algae); SLAM pool and scrub that area
    - Hold crushed vitamin C tabs in a sock against stain; if it goes away, it is iron; requires a sequestrant to manage metals in the pool; very bad pool s might require an acid wash
    - If vitamin C tabs make a spot get worse, it's copper; a sock full of dry acid may help; or a plaster acid wash for bad areas
    - Calcium stains generally occur because of high CH, coupled with high pH and TA; best removed by adjust CSI levels (lower) and scrubbing the effected area
    Hope that helps.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    This also seems to be a handy tool for stain ID for 10 bucks, Jacks Magic Stain Identification Kit JMSTAINID at Sunplay
    Here is more info on Diagnosing Pool Plaster Problems
