Results 1 to 7 of 7
Thread: Nicheless light options
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I have a Pentair Aqualumin II nicheless light in my pool. The previous owner ruined it, my ladder, and liner with granulated chlorine. I'm hoping to replace the ladder this summer. I'll have to live with the fading of the liner for a few more years. The light will come eventually when I have some extra money to blow. Anyway, last year I replaced the bulb in it and found that the housing has holes eaten through it where the gasket seals. I tried to seal it up with some underwater epoxy, but it leaked and filled half full of water over the winter. I disconnected the power wires to it a couple weeks ago. Does anybody know if there are any other lights available to replace this one? I've seen the Aqualumin III. Apparently Hayward used to make one, but they stopped making it. I've seen the small ones that screw into a return fitting. I assume that it would be nearly impossible to install extra return fittings for those lights. Anybody have any other ideas?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Apr 2013
    Sacramento, CA
    2,769
    Re: Nicheless light options
    OK I'm lost-- Pentair makes the Aqualumin III which is what you should upgrade to. You can do that now without replacing the liner.
    If the light is leaking you need to replace the light. Epoxy repairs are not something you want to do.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I'm not a fan of the current light, possibly just because the previous owner and installer screwed everything up. Besides all that one of the legs that holds the cord broke off seemingly unrelated to the corrosion. I was just wondering if there was any other options for nicheless lights. I haven't found any, so I assume they don't exist. I just wanted to poll the audience. Do you know what they changed on the aqualumin III?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Oh, and the installer didn't put in a separate junction box for the light. It apparently just T's into the main conduit going to the equipment pad. Should be real fun pulling the new cord.
    buddywiser's Avatar
    Morgantown, WV
    98
    Do you actually see the black light cord at the pad? I'm asking because I'm in a similar predicament.
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Yeah. It comes up through the 3/4 conduit with about 7 other wires.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    See my thread "Pool equipment main wiring repair- solid or stranded" for more interesting info.
