Results 1 to 7 of 7
Thread: No cya at all
    Mar 2016
    Atlanta /Ga
    3
    No cya at all
    Hi guys,
    I opened my pool this april and it was pretty green ,i followed "all" the instructions(did not used liquid chlorine,i used Cal hypo for the slam procces) in this forum and i had amazing results!! (crystal clear)
    but there is something that worries me ,it is the CYA ,ive been testing the whole month and i have not readings at all ,i know its been cold here in GA but today it was pretty warm 70s and still not Cya readings (i can still see the dark dot when i do the test)
    i bougth
    Any suggestions what should be the next step ? Some stabilizer ?
    water temp 70*
    ph - 7.8
    Ta - 100
    Ch- 160
    CYA -Unknow
    Vinyl Pool
    28000 gallons
    Regards David
    28k gal 18x36 /Vinyl/In Ground / Hayward Max-flo vs sp2302vsp /Hayward DE 4820 Pro Grid
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: No cya at all
    Welcome to TFP!!
    Let the water sample rise to room temperature before you test for CYA. If it clear to the top, then yes add stabilizer per Pool Math to get to at least 30 for now.
    You don't list what your FC level is, so how is the chlorine level?
    Support the site
    Mar 2016
    Atlanta /Ga
    3
    Re: No cya at all
    Thanks for reply that fast
    Fc 5.5
    I just took a sample of water this morning ,iam going to wait until it gets to the room temperature and then i will add the cya to see what happens.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: No cya at all
    I have to add CYA every spring. We are close in part of world. We get a lot of rain which cause water turn over. It is just a part of our pool life..........I check my CYA monthly and top off as needed.
    You are on the right track!
    Kim
    30,414
    Re: No cya at all
    You have no CYA. The cold has some effect but not enough for existing CYA not to register.
    I would calculate a dosage to get to 40 ppm and then put it in your pool.
    Mar 2016
    Atlanta /Ga
    3
    Re: No cya at all
    Well ,i just wanted to say thank you all for the advice,finally i have my CYA readings and the pool looks great and pretty balance.
    FC 3
    CC 0
    PH 7.6
    TA 100
    CYA 30
    CH 180
    Jun 2014
    15,059
    Re: No cya at all
    Holly smokes what a transformation! Outstanding. Right down to re-doing the fence. Happy pup too. One heck of an Extreme Makeover - TFP Edition.
