Thread: higher FC than should be to CYA level
    Mar 2016
    Santa Clarita,CA
    14
    Hi, if my CYA is 40 and the minimum FC is 3 , target is 5, would FC of 7 cause any problems?
    Thanks, dave
    16x36 free form gunite, 8' deep end, raised spa attached, 18,000 Gallons, Stone Scape mini pebble, remodeled 8/10/2015, Pentair variable speed pump #011018, DE filter, Pentair Easy Touch upgrade automation w/ screen logic, Pentair 520549 Easy Touch indoor control panel, is4 spa side remote, Pentair Mini Max plus 400 heater, Hayward Navigator pool vac, IntelliBrite 5G color LED light in pool and spa
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: higher FC than should be to CYA level
    No, that's what I usually keep mine at with a CYA of 40-45.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mar 2016
    Santa Clarita,CA
    14
    thank you
    Aug 2014
    Northern IL
    4,615
    Agreed that it's okay. Just don't let the current high FC let you get complacent about testing again tomorrow!
