Thread: Pump died
    May 2015
    keller
    129
    Pump died
    My friends pump died today. Single speed 2.5 hp jandy pn 7-19388-20. I reccomended replacing with a 2 speed motor. For those who have done this - where did you purchase and how did you ensure your motor was compatible with the pump?
    Also - in the mean time the plan should be to keep fc higher than normal and use a sump pump and a daily brush for circulation.
    Thanks for your help!
    Owner Builder; Under construction, 17K Gallons SWG IG Geometric; 31X20'; 600sf; 104ft perim; depth 4'-6'. Sun-shelf; bubblers; sheer descents; Dolphin M400; Pentair Intelliflo XF; Clean and Clear 520; Easytouch 8; IC40; 2 color LEDs; TF-100, K-1766, SpeedStir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pump died
    Check with pool plaza I think they are in the DFW metroplex they have a good web site for replacement parts including 2 speed motors
