Thread: Intex 6-way diverter valve gasket.
    Apr 2015
    Morton Illinois
    14
    Anyone know the part number or where to find a spider gasket for a 75lbs intex sand filter? It measures 5 1/8th in OD and 1 1/2 in ID with 4 outer holes and one center hole. I have looked all over the interwebs and cannot find it!
    Above ground 9300 gallon pool with intex 3/4 hp pump (way overpowered) and 77lbs sand filter located in Morton, Illinois.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Intex 6-way diverter valve gasket.
    It might not be sold separately. The whole valve is less than fifty bucks. Sand Filter Pumps - Replacement Parts - Above Ground Pools - Store - Intex
    Apr 2015
    Morton Illinois
    14
    Well that is what I get for buying intex I suppose. Might just upgrade the filter then. Thanks for your reply!
