Thread: Cloudy and slightly green pool
    Aug 2011
    West Covina, CA
    21
    Plaster in ground
    Temp high 70's
    FC = 7.0
    CC = 0
    TC = 7.0
    pH = 7.7
    CH = 500
    TA = 80
    CYN = 70
    Using a solar cover to raise temp.
    Using liquid Chl @ 12.5% and liquid acid.
    Pool looked great two weeks ago and after a weekend of rain it had a bit of green sediment on the bottom. Swept, adjusted chems, vacuumed, and cleaned filter. Some of the green isn't being caught by the filter and takes a couple of days to settle back to the pool bottom. I know my CH and CYN are high but I can't do a partial drain (Southern CA water restrictions). Wondering if I just keep the TC levels up around 10 and keep the pump running 24/7 or do I need to do another SLAM? Poolmath suggests a regular TC level of 5-10 with my CYN level. To SLAM would be 28. Yesterday I was around TC of 4 and pH 7.7. I added acid to lower to 7.4(ish) and chl to raise to 10. Does the TC 7-10 level give false pH readings?
    Cheers!
    Septimosprime
    *17,000gal *built in 1983 *IG Plaster *Pentair Intellifow VS pump *Pentair cartridge filter *with a spa *on water restrictions
    38,418
    Re: Cloudy and slightly green pool
    What test kit are you using?
    You need to actually complete the ShockLevelAndMAINTAIN Process by passing the 3 criteria to stop. A FC of 10ppm is not nearly high enough with your CYA level.
    The pH test is not accurate when the FC > 10ppm.
    BTW, your CYA is not really that high, so you should not need to replace water.
    Aug 2011
    West Covina, CA
    21
    Using the TF-100. 3 Criteria of CC<.5, over night drop, and clear water. I should first lower my pH from 7.7 to 7.5-7.3, right?
    Septimosprime
    38,418
    Ideally you want the pH down around 7.2 when you start the SLAM, since you will not be able to check the pH during the SLAM process.
    Aug 2011
    West Covina, CA
    21
    Ok. Will do. Thanks.
    Septimosprime
