Results 1 to 7 of 7
Thread: Leaking Pentair Mastertemp 400 Heater
    Apr 2016
    St. George, UT
    3
    Question Leaking Pentair Mastertemp 400 Heater
    Hi All!
    I purchased an 8 year old home a few months ago with a pool. All was working well until I fired up the filter pump yesterday and noticed the water level in the pool dropped after just a few of hours. After looking around I found the Pentair Mastertemp 400 heater was leaking quite substantially. I opened the side covers and found water pouring out of the 'air orifice grill'.
    I haven't delved into it deeper yet as I wanted to get feedback about whether this is a common problem, and if there are any possible solutions. I get the feeling this isn't going to be easy or cheap. Thoughts?
    Thanks
    Jun 2012
    western NY
    1,562
    Re: Leaking Pentair Mastertemp 400 Heater
    Sorry to say this, but it sounds like the heat exchanger is shot.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Yep heat exchanger is shot. The can is full of water. Get a Raypak to replace it if you have the room.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Apr 2016
    St. George, UT
    3
    Thanks for the confirmation. It's not what I wanted to hear, but that seems to be how things are going lately. I'll have to measure the utility area and see how much room I have available for a larger unit before I start looking.
    One follow-up question - should I consider a heat pump instead? I live in a warm enough area that it would be nice to save the operating costs of a gas heater. The Mastertemp was 400BUH, but I don't see any heat pumps that put out that kind of heat. Any pointers in the right direction will be much appreciated.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Do you just have a pool or do you have an attached spa also? There are lots of opinions on gas vs electric but here is my take on it. If you ever want to use the pool during any times when the temp is 60 degrees or less, a heat pump is inefficient at that point and produces very little heat. If you ever want fast heat ups, gas is the way to go. You are correct in that heat pumps do not come in a BTU size even close to what your gas unit is.
    Paul
    Apr 2016
    St. George, UT
    3
    I have both a pool and spa. I was shocked at the cost of heating the spa a few times over the past few months, even though the outside temps averaged between 45 and 75. It looks like I could save some cash in the spring and fall by going with a heat pump, but I'd have to forego spa use over the winter. Ahhh, decisions, decisions.
    I've been researching heaters online, and planning on talking to local pool guys this weekend, but would appreciate a knowledgable (non-biased?) opinion on a replacement heater. I've read many bad things about the Mastertemp 400, but I've also read good things. If you were in my situation, what heater would you get?
    I would estimate my pool at around 23k gallons, spa, unknown make, Pentair control system, sand filter. Average temps in the summer are around 95 high, 70 low.- winter 50 high 30 low. So, the million dollar question is what heater would you get?
    Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Raypak are the most popular heaters here on TFP.
