Thread: Homemade overflow port?
    May 2013
    Long Island NY
    419
    So I have a in ground pool that's surrounded by a wood deck that's 18" high from ground level. My pool doesn't have a overflow and durning the fall, early spring when my pump is removed I have to siphon the water out when it fills with rain. So I thought I would make my own. My thought is to install a fitting inside one of the skimmers by drilling a hole about 2" above where I normally keep my water level, I would think a fitting with a 3/8 hole dia. would work and then attach a piece of tubing too the other side of the fitting for my discharge, and just let if drain into the grass. I don't want to just drill a hole and let it drain under the deck close to the pool, I want to get the water away, thus the tubing. Is there such a fitting like that ? Any ideas on a alternative fitting?
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    38,524
    Re: Homemade overflow port?
    I think you would want to find some kind of bulkhead fitting to attach to the skimmer and then you should be able to use brass or PVC adapters to connect a pipe or hose.
    May 2013
    Long Island NY
    419
    Ok, bulkhead is the word. I will look using that. Otherwise I may just epoxy in a 3/8 piece of sprinkler riser pipe and that would also work I guess. Thanks
    Bingo! All sorts of choices using bulkhead fitting. Thanks again
    38,524
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Post us up some pics and list of what you used to help other folks out as well. Love to see it.
