Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Weighting down Conter Steps with corner step.
    Jan 2010
    Randleman,NC
    620
    OK,getting my new steps together. I don't want to put sand in them and I don't want to spend a fortune on material .I have seen different solutions from PVC to Jug's.Thinking of using pea gravel .Thought about bleach Jug's and hanging them on inside of steps with marine rope and some thick wire straps. Any suggestions
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jul 2012
    Chicago, IL
    356
    Re: Weighting down Conter Steps with corner step.
    I used bleach jugs, filled them with quikrete and added water. So far that has worked better than any other method I've tried. My steps have a shelf for the weights so I did not need to hang.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by Pauls234 View Post
    Never thought about putting quikrete in jugs and add water.What was your mix ratio?Weight of jug after doing that?
    Jan 2010
    Randleman,NC
    620
    Also,when using PVC what is the best cement to use.Worried about it coming un-glued.Also,notice people using 3 in Pipe.Looking at 23 in lengths.On average how many will it take to get 70 pounds
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I like blue PVC glue best. It works wet or dry.
    Jan 2010
    Randleman,NC
    620
    Thank You
    Quote Originally Posted by pooldv View Post
    Apr 2013
    East Bethel, MN
    19
    I have the same steps; I've tried the jugs of concrete, pvc pipes filled with concrete - all to no avail. What worked for me was picking up 2 25 pound dumbbells from Wal-mart - the plastic coated kind. I placed them on the back support bar under the steps. I also placed a pad under the steps so the weights lean off the support bar and onto the pad. Worked great and it was the first year my steps didn't move
    2013 21,500 Gal. 28' Round AB Doughboy
    DE Filter, Taylor K-2006 Test Kit
    Solar & Rheem 400k heat
    Jul 2012
    Chicago, IL
    356
    Quote Originally Posted by kplaster View Post
    Sent from my XT1030 using Tapatalk
    I wasn't that precise on the mix ratio, just tried to be in the ballpark of what was suggested on the package. Can't recall the weight of them either, maybe around 20 pounds? I'll weigh one this weekend and report back.
    Pouring the quikrete into that little hole was tricky, I tried a funnel but the opening often clogged with the larger pebbles. I ended up making a funnel with poster board or something similar so I could manipulate the size of the opening and that made it much easier. I made maybe 10 of these to not only hold down the stairs, but also my makeshift islands that I have throughout the pool so I wanted something that could be taken in and out fairly easily. The handles really help with that.
    Jan 2010
    Randleman,NC
    620
    Thank You,I'm looking at ease of getting them up at the end of season.Thought about attaching marine rope to them to be able to pull out of water.Trying to find new empty Jug's.But,the price of them I can just buy cheap jugs of bleach and pour out for the jugs.
    Jan 2010
    Randleman,NC
    620
    Well,we picked up a 50 pound bag of concrete mix and some rope.We rounded up several empty bleach bottles So we going to try to get the jug's started tomorrow.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I ended up putting the sand in them, as I couldn't get anything to stay and the front kept floating up.
    Jan 2010
    Randleman,NC
    620
    Well,we got 6 jugs done.They are about 16 pounds wet.Got rope and big zip ties. Figure will place one in each corner.Strap them in and tie rope to all them and tie rope so I can reach and pull out of water when needed.
    Jul 2012
    Chicago, IL
    356
    Nice, let us know how it works. Might not be a bad idea to pour a bit of bleach in the bottles occasionally. I had a very low level algae growth (only aware because of dead algae on appearing on the bottom) end of last year so was wondering if the bottles became a bit of a safe harbor.
    Kathe's Avatar
    Jun 2015
    Saline, MI
    46
    In our steps, we put small bricks into ziplock freezer bags. Then put them in. I didn't want the surface of the bricks to corrode into the pool or get algae on them. Seems to be working.
    Above ground 27' round, 17,000 gal., 52" high; vinyl liner; TropiCal 96,000BTU Heat pump; Integrity A Frame Ladder; Solar Blanket, Aqua Cover by PolyAir Corp, thermotex clear, 5 yr. warranty, cartridge filter., Clear Bay Cartridge CBA2-10043 (two to switch out when cleaning); New pool as of 6/1/15.
    Jan 2010
    Randleman,NC
    620
    Well,we got them hung with big zip tie's.Got'a get tub mat's before putting in water.I've gone back to work now so it's hard to get project completed.I will get pictures before dropping in pool.
    Casey's Avatar
    SW PA
    10,422
    I use sand, bleach bottles and bungee cords with plastic hooks.
    The green ones hold the bleach bottles n the blue ones keep the steps up against the wall n clip onto the top rail. I lije being able to move them easily to clean.
    Jan 2010
    Randleman,NC
    620
    Well,that didn't work.Had 6 jug 's weighing about 15 or so a PC.Still not enough to hold in water.Ugg.Finally got it warm enough to get in today.O'well..Pulled it back out.T his is what we have now.Got two Jug's hung on side step
    Jul 2014
    Oakbank, Canada
    389
    Mine have holes in at the top for filling them with water, that keeps them in place. There is plugs for the holes too for when they are full. Could you no just drill a 3/4" hole into each leg near the top, fill them, and then put a plug in?
    All these ladders appear to be hollow, so why not fill with water and plug?
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by DarrelB View Post
    They are designed to add sand to them.Pop the plugs and add sand then put plug back in.But,I really didn't want to put 70 plus pound's of sand in them.Pain to get put of water.
  20. Back To Top    #20
    Jan 2010
    Randleman,NC
    620
    So my ? is the cavity for sand.Is it just a empty area that water can't get to.Which would leave a air spot.Thinking I need to make a couple more jug's or just try to get to bottom sand hole and add sand only to bottom area.
