Results 1 to 12 of 12
Thread: Bottom Drain law? (2016)
    Jul 2014
    Frankfort KY
    6
    Hello Friends!
    i was unable to find anything recent on the topic of Bottom Drains being required. So, the backstory!
    My Vinyl liner died. It was old when I bought the house so it wasn't my fault.
    The local installer is telling me that he must install 2 bottom drains to be compliant with Federal Law that requires 2 bottom drains so no one gets stuck to one again. I believe he was quoting the Brady pool act.
    My pool is old, and does not have any bottom drains. It has 2 skimmers though.
    Is this something anyone has run against recently?
    Thanks for sharing your experience!
    19K gal, IG, 16x32 vinyl, sand filter and 1HP pump look like Hayward models, on an Intermatic timer.
    Testing with K-2006, LaMotte Borate strips, Aqua Check salt strips to fill in all the spaces in Pool Math!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Bottom Drain law? (2016)
    I know of no laws or requirements that a pool MUST have a bottom drain. Now, if it does it should be Virginia Graeme Baker Pool & Spa Safety Act compliant.
    As one of the methods for a pool to be compliant is to disable an existing non-compliant bottom drain I don't see where two need to be added to a pool that doesn't have any. My gut feeling is that the guy is trying to inflate the work for more $$$
    Ask him to please provide a copy of the "law" or a citation/statute number so you can look it up.
    Support the site
    May 2013
    Albany, NY
    59
    Virginia Graeme Baker act (or something similar) calls for dual main drains 3' apart or one long bottom drain over a certain square footage, due to the risk of entrapment / evisceration with smaller single main drains. If you do some research on this site though, you'll notice that many are in favor of no main drains at all. Common reasons include the fact that proper circulation and cleaning can be accomplished with strategic skim units and returns, the risk of liner / plumbing failure under the pool structure where access is difficult, and additional labor and expense.
    IMHO, I would go without main drains, especially if you're not already plumbed in for them. You don't mention dimensions of your pool, but based off your gallonage, your two skimmer should be more than sufficient for cleaning / circulation. How many returns do you have?
    EDIT: Tim beat me to it!
    Eric Adams, Technical Specialist, Radiant Pools
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by tim5055 View Post
    Much of these new laws, statutes, etc are passed for commercial pools and even if they are passed to cover residential pools, pools that are already built are exempted and it only applies to new constructions. You need details. If in doubt, contact your local government such as city, county and state.
    Isolated Spa - 345 Gallons
    Jul 2014
    Frankfort KY
    6
    Thanks guys! I was of the same opinion that it would only count for pools that already had one drain only as well, but my Google skills were failing me as well as my lack of comprehension of the language lawyers use. The pool is 16x32 oval with 8' deep end and a very narrow 3' shallow end. I was able to get good circulation with the system as is. (2 skimmers, 2 returns, and the leaves pile in one small area for easy removal).
    I am not sure the local installer is trying to up the cost as much as he may be wrong about the application of the law, or trying to price himself out of the job. I have had lots of experience with that recently in this area.
    I will ask for a copy of the law/ordinance/statute thingy and see what happens.
    There is no law requiring you to add one or more main drains to your existing pool with no main drain. He's probably just misunderstanding the law. In any case, ask him to cite the specific law and the section that he claims applies.
    Support the site
    Apr 2013
    Sacramento, CA
    2,769
    He may be saying that since you are replacing the liner that counts as a retrofit or renovation which means you must bring it up to current code. He might be correct there. That would be your local law.
    Mar 2013
    New Hampshire
    351
    Ours was built in 2013 and has 2 drains in the deep end. I thought that was standard.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by doobs41378 View Post
    If you have drains, two is standard. Any other method of compliance is more expensive.
    Support the site
    Mar 2016
    Chino Hills, CA
    190
    Our pool/spa was completed two months ago and both have two drains.
    30,000 Gallon Pool IG (Pool 18' X 38' / Spa 7' X 7') - Pentair IC40 SWG - (1) Pentair Intelliflo 2 VST Pump - Pentair DE FNS-Plus 60 Filter - Pentair Mastertemp 400 Heater - Pentair Easytouch 8 - Pentair Electronic valves - Pentair 5G Color LED Pool/Spa Lights - Pebble Sheen Mini Tahoe Blue - Auto Fill/Over Flow - Taylor K-2006C - Completion 3/2016.
    Jul 2014
    Frankfort KY
    6
    Just so when I forget and search for the answer again I can find it
    Locally, the recommendation for leaking or going bad bottom drains is to abandon them in place.
    New pools with a bottom drain must have 2, but a residential pool does not need to have a bottom drain system.
    Some careful aiming with returns can get very good circulation and that seems to be enough for my pool and the recommendation of the crew doing my new liner.
    When we had our liner installed four years ago, I was told the same thing. Our pump has an automatic shutoff if it detects any sort of blockage on the drain, or skimmer. Because of this, I was able to get out of them "Having to do it."
    26,000 Inground Vinyl, 16' x 32'. Pentair Intelliflo SVRS, with 30" Hayward Pro Sand filter.
