Hard pipe. Need help with gate valve.
Mar 29, 2016
88
Chicago,IL
My waterway pump has a gate valve that has a air line off on it going into the pump strainer basket feeding from the skimmer. It has a straight end on it to pipe clamp a hose on it. I want to hard pipe the lines and there is a valve-air like valve on the bottom that isn't attached to anything? Does this allow a small amount of air to flow in the pump? Was something suppose
to be attached? I was gonna grab a new union and not use this piece. Is this okay or do I need that piece because of the bottom valve thing
So I found on there website:
  • 3/8″ barbed fitting to accommodate offline chlorinators
weird this would be before the filter as I thought it should be after. Im assuming I don't have to worry about this nipple and just replace the hole piece.
