Thread: Hard pipe. Need help with gate valve.
    Mar 2016
    Chicago,IL
    88
    My waterway pump has a gate valve that has a air line off on it going into the pump strainer basket feeding from the skimmer. It has a straight end on it to pipe clamp a hose on it. I want to hard pipe the lines and there is a valve-air like valve on the bottom that isn't attached to anything? Does this allow a small amount of air to flow in the pump? Was something suppose
    to be attached? I was gonna grab a new union and not use this piece. Is this okay or do I need that piece because of the bottom valve thing
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Mar 2016
    Chicago,IL
    88
    Re: Hard pipe. Need help with gate valve.
    So I found on there website:
    • 3/8″ barbed fitting to accommodate offline chlorinators
    weird this would be before the filter as I thought it should be after. Im assuming I don't have to worry about this nipple and just replace the hole piece.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Correct, that should have been plumbed after the filter.
