Thread: Can I add Diatomaceous Earth to any sand filter?
    My apologies if this has been discussed before. Can I add DE to ANY sand filter, or does it have to be a specially designed filter? If I can, what is easiest way to do it?
    15,000 gal + Spa 500 gal, Fiberglass, SWG, Pentair variable speed pump, Pentair Easy Touch, Aqua Cal heat pump
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Can I add Diatomaceous Earth to any sand filter?
    You can, just make sure it's pool grade DE and NOT food grade, which would make a cloudy mess of your water.
    Dolphin E10 Cleaning Robot.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Isolated Spa - 345 Gallons
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    I have a link for you:
    Pool School - Add DE to a Sand Filter
    I have done it and LOVE the polished look of the water.
    Just make sure you can babysit the pool for a couple of hours until you see how much DE YOUR filter likes. Some only like 2 Tablespoons and mine likes 1.5 cups!
    Kim
