Results 1 to 8 of 8
Thread: why would all of a sudden you need more that 2 dippers
    Aug 2008
    Las Vegas, NV
    116
    of DPD powder to turn your test sample pink. Up until this point, I've always had bright hot pink with two dippers and today, I had to use three.
    Pam
    Re: why would all of a sudden you need more that 2 dippers
    Normally you need more R-0870 powder when the FC level is higher. There is also some variation in how much the scoop actually holds, since the powder grains are fairly large relative to the scoop.
    Aug 2008
    Las Vegas, NV
    116
    ahhh haaa...You guys are so smart!
    That would be right because I had shocked the pool and the FC was pretty up there.
    Pam
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I thought you only used "one heaping scoop" no matter what. how do you know to use two or three? it has to become hot pink?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Just pink. My2, You are using the "scoop end", right? Not the flat end?
    Even at shock levels my solution has always turned pink with one heaping scoop.
    Jan 2009
    Cupertino, CA
    1,966
    My instructions say if the pink appears and disappears, add more powder.
    I've never seen this myself, but apparently somebody else said it could happen and that's what to do about it.
    --paulr
    BBB "Intermediate Swimmer"
    Aug 2008
    Las Vegas, NV
    116
    I'm using the scoop end.
    My test kits says to use 2 scoops and if it doesn't stay pink, add more.
    I have to keep my chlorine high b/c of a high CYA. I think I may work on doing more of a drain and refill, but since I'm moving this summer I haven't made up my mind. We brought out CYA down a good bit over the winter months by doing several drain and refills. We are 100-120 now.
    Yesterday was the first time I had to use more than 2 scoops, but I had shocked the pool the day before.
    Pam
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Quote Originally Posted by frustratedpoolmom
    I made that mistake when I first got the test kit.
    14100 gallon IG Gunite Pool
    Sapphire Smoke Quartz Plaster
    Pentair SunTouch Controller, Intelliflo 4x160 Pump, 520 Cartridge Filter, Intellichlor SWG System
    Legend Platinum Cleaner with booster pump
    My Pool Build
