Thread: New (to me) spa
    Apr 2016
    St. Louis, MO
    9
    New (to me) spa
    First time spa owner here. Bought this house with a pool and a separate spa on Monday. I've been getting moved in and trying to get a handle on the pool chemistry, so I'm just now getting around to the spa. I tested the water this am with the TF-100, results are below.
    pH: 7.8
    FC: 1
    CC: .5
    CH: 125
    TA: 150
    CYA: 80
    So i assume I need to bring the pH down a bit, but what else do I need to do? The owners manual says that if I have an ozonator FC should be between 1 and 3. So am I good there? And there is a bucket of chemicals next to the spa with pH up, pH down, chlorine granules, algaecide, and a few others. Should I use these for now? Dump em?
    And finally, what do I need to do moving forward to take care of the spa? Change/clean filters? Set some kind of timer for the ozonator?
    30k free form IG gunnite pool with 1.5 hp challenger pump, sta-rite sand filter, SWG, and Rheem heater.
    2002 425 gal cal spa fiesta series spa with ozonator.
    38,354
    Re: New (to me) spa
    I would not adjust the recommended FC levels due to the ozone.
    You need to follow the FC/CYA Chart so your FC is much too low for your CYA level (which is higher than you need, likely due to the granules).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: New (to me) spa
    PH up/down is fine. Skip the rest.
    This is how I have been maintaining my hot tub for a few years. It works great! How do I use Chlorine in my Spa (or pool)?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New (to me) spa
    I would also suggest now may be a good time to replace that water and get the CYA level down, I suspect the previous owner used dichlor exclusively.
    You may want to check out the dichlor then bleach method
    Dichlor - then bleach method
    Ike
    ps how old is the ozonator, many types stop making Ozone after 3-4 years (some newer models may last 5-7 years) most also just have a power indicator light which does not tell you if they are producing ozone. There are one time (break glass draw tube) style testers for ozone, but given they cost around $15 each, and you can get a new Del brand ozonator off ebay for about $100, I question their value.
