Thread: Salt balance and other chemistries?
    tdp's Avatar
    Sep 2015
    Suburban Philadelphia
    57
    Question Salt balance and other chemistries?
    Can I work on balancing the FC, TA, etc. before getting the salt level to the proper level in my just-opened pool? I have a SWG but am leaving it off until I get the proper salt level (and using bleach to add chlorine) but I am raising the salt level slowly so I don't overshoot. The amount of salt in the water shouldn't matter to the other chemistries unless the SWG is running, right?
    ~17,500 gal. IG Fiberglass, Viking "Cambridge"; installed 6/2015
    SWG Hayward Turbo Cell T-9
    Hayward Hi-Rate Sand Filter
    Hayward Max-Flo XL pump
    TF-100 Test Kit/SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Salt balance and other chemistries?
    Yes, that is correct. Here is what you are aiming for, Pool School - Water Balance for SWGs
