Thread: Tiger Shark pool cleaner question
    Jul 2010
    Apopka, Fl
    31
    I have a 12 year old Tiger Shark that has performed flawlessly until now. I took a lightning hit last summer that took out my power supply. I just bought a used one and it is working...power goes to the cleaner, impeller turns and pushes out water but the cleaner will only move about a foot then stops. I took it apart to be sure nothing was blocking the belt and all seems good. Out of the pool upside down it will track for a few seconds then stop. It did sit in my garage for a year and the drive belts are worn, but it was fine until the lightning took out my power supply and I parked it...any Ideas? thanks
    Inground 15x30 oval, plaster, 11250 gallons(?) with pool cage...jandy 100sq ft cartridge filter... SWG...Taylor K2006 Test Kit
    Located Apopka, Fl...Orlando area!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Tiger Shark pool cleaner question
    I have the same cleaner, probably just as old. Sounds like it could be an issue with the motor/controller within the unit itself. You could try replacing the motor assembly, but you're looking at $350-500 there. Might as well look into an entirely new robot at that price since you could get all new and not just a worn out robot with new guts. If it was 12 years in operation, in Florida, it served well.
    Isolated Spa - 345 Gallons
