Results 1 to 12 of 12
Thread: Salt generator problem
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Just plugged in my Intex 8110 SWG no power GFCI wouldn't even reset. I have 7110 Intex SWG for spear parts is it possible to switch out the transformer with the 8110. I notice that the 8110 transformer casing is a little taller than the 7110.
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Apr 2016
    Kankakee Il
    39
    Re: Salt generator problem
    I am assuming it will reset without it being plugged in?
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    It should but it's not
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I would say probably yes. It is unlikely that they would spec different voltage. Are there any voltage or amperage specs on anything?
    Apr 2016
    Kankakee Il
    39
    if the gfci receptacle will not reset with nothing plugged into it, it is faulty and must be replaced.
    Last edited by jason176; 04-22-2016 at 08:48 PM. Reason: Sorry, I didn't realize they had a gfci built into the cord. I assumed we were talking about a receptacle.
    Apr 2016
    Kankakee Il
    39
    Ok, so editing is apparently not my strong suit, lol. I hate it when equipment comes with those on the cord, you have no way of verifying if the equipment is bleeding current to ground or if the gfci is bad (which can happen, especially since they aren't the highest of quality). I poked around on the intex site and they dont even list the power supply as a replacement part. The manual says the 8110 uses almost twice the current of the 7110 so basically you probably cant swap them.
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Quote Originally Posted by jason176 View Post
    Yes the 7110
    110/120 V
    0.6 A
    65w
    ECO 500MA
    8110
    110/120V
    1.1A
    125W
    ECO 800MA
    It's under a 2 year warranty but Intex will not accept it cause I don't have my receipt
    DFW, TX
    24,502
    Dang, that's not good. Swapping them isn't going to work. Time for some bleach!
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    I got a brand new 7110 model so I'm using that one
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Is there Anyone with a purchase recept for the Intex ECO 8110 that don't mind share a copy of your recept with me. Can't find mines need it for warranty. Thanks in advance
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Quote Originally Posted by pooldv View Post
    Got a back up the 7110
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    I finally decided to replace the plug on my 8810 and it works fine now. I cut out the old cord and replaced it with another that I had on older unit
