Thread: commercial indoor got tub
    Dec 2015
    Converse
    17
    I'm maintaining an indoor 2000 gal plastered hot tub with highly fluctuating bather load three times a week. Hot tub is completely drained weekly. Currently only using inline bromine feeder. So obviously my feeder dial is set to accommodate a normal bather load. I know there was a higher bather load then expected when I return and my water clarity is horrible. I am about to push for automated chemical feeders using sodium hypochlorite and non fuming acid. Looking for best solution for 3 visits weekly. Also looked at ozone and UV, but didn't think it nessassary with automated feeders. I think I'm on the right track but just want to be 100% positive.
    Donldson's Avatar
    NW Ohio
    2,892
    Re: commercial indoor got tub
    I would think in a bromine tub that using ozone would be similar to using a liquid chlorine injector since the ozone will activate the bromine, unlike a chlorine tub where it is only a secondary oxidizer.
    What kind of limits are you working with? Does it have to be bromine? What are your chemistry requirements?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Dec 2015
    Converse
    17
    Must use bromine, other then that no other limits. A commercial ozone system with a tank would be the system I would need? Then I was thinking with automated shock feeder it will only at when needed. So I'm thinking cost would benighted the feeder
    Dec 2015
    Converse
    17
    Shock feeder will monitor pH and ORP and add accordingly, as well as being cheaper
    Donldson's Avatar
    NW Ohio
    2,892
    Ah yes, commercial sized. I always forget about commercial sizing things. Yes, feeding liquid chlorine will work fine. Frankly with that setup you could probably decrease the use of bromine tablets, since during the slow times they are likely increasing the Br level more than you would want. So that would give an additional small savings.
