Results 1 to 12 of 12
Thread: Auto cover won't open
    Jun 2014
    Bloomington (Minneapolis), MN
    110
    Hey all, getting ready to open my pool for the season and the cover won't open. I hit the switch and it just buzzes/hums. Any idea what could be going on? Is the water level maybe too low?
    Pool: 28K gal, vinyl lined, rectangular, auto cover
    Equipment: Mineral Springs MS-10 SWG, Raypak 266A heater, Jandy CL460 cartridge filter, Pentair superflo 1hp 2spd pump, Polaris PB4-60 booster pump and Polaris 280 cleaner. TF-100 w/speed-stir
    Jun 2014
    15,221
    Re: Auto cover won't open
    Thought I would bump this post to see if you ever got your cover issue resolved. I personally don't have a cover so I can't really contribute to the specifics, but didn't want you to think we didn't see your post. I wouldn't see why the water level would matter though. A buzz/hum tells me you're getting power, but perhaps the motor itself is frozen (grit, rust, or mechanically - not cold), so perhaps there's a manual override or disengagement/release option? Again, not my specific area of expertise, but wanted to check on your anyways.
    Jun 2014
    110
    Quote Originally Posted by Texas Splash View Post
    Thank you! Ya, I have no idea what's going on. Worked fine when I closed it in September..
    Aug 2014
    Northern IL
    4,615
    Did you raise the roller-ends to summer level?
    Jun 2014
    110
    Quote Originally Posted by MarianParoo View Post
    What does that mean? I didn't lower anything in the winter?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    While attempting to move the cover, can you visually look at where the motor connects to the shaft of the cover reel? Remove the cover over the motor if necessary to see this. Is the motor shaft engaged with the reel shaft? Is the motor spinning or just humming in place?
    Isolated Spa - 345 Gallons
    Jun 2014
    110
    Quote Originally Posted by JVTrain View Post
    Got it going! Was just way underfilled. Where in Central MN are you? I went to school in St. Cloud and our cabin is in Alexandria. Not sure if those count as central or not ha.
    Jun 2014
    110
    Is there a trick to cleaning the housing out? The housing cover has to be held open, I need more hands...
    Aug 2014
    Northern IL
    4,615
    Do you have a feature in the way, like a diving board? In order to clean out our "housing", we have to remove the board from its platform. Then the "housing" hatch just flips open.
    Jun 2014
    110
    Ya I have a diving board, but the cover stops before hitting it
    Aug 2014
    Northern IL
    4,615
    Ours too. But the housing hatch won't fully open with the board in the way. How about posting a picture?
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Scsu74 View Post
    I guessed you went to SCSU by the user name. I live west of St. Cloud about 20 miles. The Alex area has some great lakes and is certainly central MN!
