Results 1 to 12 of 12
Thread: When to open pool
    May 2015
    Wichita KS
    29
    When to open pool
    Hello all! I'm looking for some advice on when to set up my new Intex pool. I live in the Midwest and currently (looking at Accuweather's extended forecast) it looks like a lot of rain off and on with the temps not getting into the 90's until late June.
    I have the groundwork almost done but hesitant to actually put up the pool until it's warm enough to actually swim. Is there any good reason to put it up now and maintain it for another couple months if I won't really be able to use it? Never have had a pool before. Thanks!
    Coleman 18'x48' AGP
    Intex Krystal Clear Sand Filter Pump 2800GPH
    Intex SWG
    **Under Construction** :)
    lovestoswim's Avatar
    May 2015
    Milford, Ohio
    102
    Re: When to open pool
    Quote Originally Posted by rdy2fly View Post
    It's good to get it up and get your water chemistry balanced and ready. That way if you run into any snags you will have time to get them straightened out before swimming weather hits!
    We installed our pool last May and boy did it take way longer than planned.....hopefully your install is seamless. Be sure to post pictures of your progress! Everyone here is so helpful....and they know what they are talking about!
    24,000 gallon, 21x43 Oval Wilbur AGP installed June 2015. 10'X24' deck. 2hp Aqua Pro Cartridge Filter. Using TFP method.
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    I opened my pool 4 weeks ago
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I opened mine the third week of March. I did my seasonal inaugural swim at 55 degrees. The kids and I went for a swim last week when it was 69 degrees.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Casey's Avatar
    SW PA
    10,450
    I just opened mine. I'll maintain it until it warms up enough to swim. That could be May or June.
    Jun 2012
    MA
    347
    You should set it up about a week or two before you think that you will use it. This will give you some time in case of any issues. Otherwise you will be wasting a lot of money in bleach and electricity. We were swimming in my pool the same day that I set it up. I must have good tap water because I have always filled it and added chemicals and have never had to slam or shock my pools.
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Quote Originally Posted by Casey View Post
    Casey, your a whimp I jumped in last Friday and was cold for two hours after getting out of the pool. Don't wait, just jump in?
    May 2014
    Lake Forest, IL
    53
    I live in chicago and opened mine april 20. It is going to be 80 on Sunday and plan to use. Obviously will need to run the heater for some time as the water temp is 55 degrees currently.
    Intex Ultra Frame 16' by 48" deep - Pentair Superflo 1.5 HP pump with sand filter, Hayward H150 Heater, Hayward Skimmer and 2nd return
    May 2015
    Wichita KS
    29
    Thank you everyone for your replies. I am excited about my first pool, just didn't want to jump the gun if it was going to be a waste. I don't have a heater, so not sure how much it will get used until it's really hot out. But we'll see!
    Coleman 18'x48' AGP
    Intex SWG
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    I got mine from 55 to a high of 72 in 3 days! But alas the weather changed and it's back to 69. Chemistry is close, clarity is good, next time it's over 70 I'm in!
    Cheers,
    Get yourself a solar setup, you may find you gain a few weeks at the beginning and the end of summer.
    Good luck!
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Apr 2016
    Casa Grande, AZ
    66
    This brings up a question for me - warmth will not be an issue for long here in AZ!!! Although we are supposed to have a little cold spell next week (from mid-90s today down to about 80 for a couple of days next week) - it will heat back up quickly. BUT, is there a thread that tells me what to do before we actually start swimming? Goal is to have the pool up tomorrow afternoon - what chemicals should I be getting to put in right away - my TF-100 wont be here until next week.
    May 2015
    Milford, Ohio
    102
    Quote Originally Posted by sh9730 View Post
    You will need bleach (household is fine or any liquid chlorine as long as it is at least 8%), some stabilizer, and muriatic acid (MA). Muriatic Acid is used to lower PH - but the first couple of things you will use is the bleach (chlorine) and stabilizer. There is a link somewhere in here called the pool school. You will want to read that and get to understanding the chemistry - but it s SUPER easy! Best of luck of your setup - Nichole
