Thread: Simple valve sizing question...
    Apr 2016
    Conshohocken
    1
    I'm having issues with my pool heater. I want to be able to be able to bypass the heater when needed. I can't afford the fix so until I can fix the heater, I just want to change the flow to the pool. When I get a new heater I just want to change the flow to the new heater.
    I need a 3 port positive seal valve. There is a 2" pvc pipe coming from the filter to the heater. There is a 2" pvc pipe coming from the heater out to the pool. I'm simply confused at all the available valves sizes. I would have thought the would be a 2"-2" valve. One 2" in, two separate 2" out. I know they exist since there is a valve in my setup that is exactly what I want. I am looking at Jandy models and I don't see a 2"-2" positive seal 3 port valve.
    I know I am missing something fundamentally with measurements!!!!
    TIA....
    4716 Jandy Pro Series Neverlube 2 - 2 1/2" Positive Seal, 2 Port Valve
    4717 Jandy Pro Series Neverlube 2"-2 1/2", Positive Seal 3 Port Valve
    4724 Jandy Pro Series Neverlube 1 1/2-2" Positive Seal, 2 Port Valve
    4944 Jandy Pro Series Neverlube 2" -2 1/2", Positive Seal 3 Port Valve
    4945 Jandy Pro Series Neverlube 1 1/2-2" Positive Seal, 3 Port Valve, internal and external stop, B23
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Simple valve sizing question...
    Jandy valves do something I wish pipe manufacturers would do: they make the ends dual-sized. So the smaller diameter is the inside pipe size, and the larger diameter is what size coupler fits on the outside. It just depends on how you want to connect things. You can use any of them.
    38,521
    I would suggest the 2"-2.5" size. They are bigger, less head loss and have a similar price. Also they you do not need to use couplers, the 2" pipe goes right into the valve.
