Thread: Should be looking somewhere else?
    Jul 2010
    Kaufman, Texas
    8
    We keep our pool balanced over the winter (N-TX - east of Dallas). As part of opening, we do a mustard algae level shock. This year, we've had a tough time keeping the FC up over night. We've been at it over 2 week, and I'm wondering if I should carry on or look somewhere else for the issue. We're loosing about 6 ppm overnight and about 12 ppm (sunny day). We have had lots of rain, so I know that could be slowing the process down.
    New chemical refills (TF-100) / using 8.25% bleach (walmart) and 65% calHypo granular (leslie's brand) - alternating for shock. I use poolcalculator.com to adjust my chemicals/ 30,000gal - variable depth; running the robotic pool cleaner to grab dead stuff as we go
    Hubby is brushing sides at least every other day. Readings tonight (after taking it back to 26 TC this morning)
    TC - 20
    CC - 1 (fluctuates between .5 and 1)
    FC - 19
    pH - between 7.8 and 8.0 (high, but I kind of expected it with high chlorine level)
    TA - 90 (high for my pool, but also expected at this point)
    Borates - 30 (where I expected it to be)
    CYA - 30
    I'm considering upping the CYA to try and hold the FC a little more steady, but not being able to break the CC is worrisome. Do you think it might just be the frequent rains? My plan was to bring the pH/TA back down into range after we get a good overnight. I also have enough boric acid to get my Borates back to 40 for the season.
    Any thoughts/suggestions are appreciated as always!
    Rachael
    21x41 Oval Doughboy Autumn Breeze installed mostly inground
    Vari-depth Vinyl liner (4ft/6.5ft - about 30K gallon)
    1HP Jandy ProFlow / Jandy CV460 Cartridge Filter
    Maytronics Dolphin Premier Robotic Cleaner
    TF-100 for chemistry / BBB Method / Borates
    Jun 2014
    15,030
    Re: Should be looking somewhere else?
    Hi Rachael. Based on everything you're saying, I would recommend letting the FC settle down to 12, which is where it should be for your CYA of 30, and continue a SLAM. After you pass the regular SLAM, then you can take the FC up a few notches to the prescribed mustard algae level for 24 hours if needed. In the meantime, make sure you've checked everything and anything in your pool (ladder, light niche, etc) anything that could hold algae. Something is chewing that stuff (FC) up at night, so the CYA level has nothing to do with it. Maintain that FC of 12 and follow everything on the SLAM page below. Be patient and consistent and you should see results. Keep us posted.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Look behind lights and inside ladder rungs for lurking algae. Also, huge amounts of organic debris inside the filter or baskets will consume a lot of FC. Check out the pictures in these threads:
    Ladder Problem Found and Ideas needed
    Another ladder Water problems
    Pool light Think I may have found my FC demand issue?
    Jul 2010
    Kaufman, Texas
    8
    We have one of those wedding cake steps and I have to get in there every year with a snorkle and a scrub brush - I try to wait until the temp is up to at least 70 before I hop in Thanks!
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    how does the water look? if you have algae outbreak, then loosing your FC makes sense.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
