Thread: Hose from build sticking out of ground
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    Hi. I'm getting ready to finish the area around my pool that was built last year and the hose that was put underground in the deep end (to pump water out if need be I suppose) is still sticking out of the ground. Do I need this for the future (should I cut it and plug it)? Or can I just cut and burry it? Asking bc I'd have to go out and buy a plug. Thanks
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    38,541
    Re: Hose from build sticking out of ground
    That is how they left it ?!?!!?
    I would not recommend getting grid of it since you might need to pump the water out in the future. Maybe add an irrigation box where you have it cut, and install a female threaded fitting and a cap? Then you could thread another hose on in the future if needed.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    That is not awesome. Is it open on the end? I would point it toward a convenient place where you would want to drain/pump water, bury it and put it in a box as bliz suggests.
    Apr 2015
    New York
    428
    That's what I did. I called the PB and they said when liner is changed down the road it would be used to pump out water if needed. Thanks to all.
    38,541
