Results 1 to 13 of 13
Thread: Question about CC
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Question about CC
    I have been having a little trouble with my SWG settings, and I have addressed those issues in that forum. My FC is at 7.5 this afternoon, and my CC is at 0.5, This morning my CC showed 0, crystal clear water. Yesterday I did two chlorine tests, and one time CC was 0 and the other time it was 0.5. What am I doing wrong, or am I just over thinking this. BTW my CYA is 70.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Jun 2014
    15,149
    Re: Question about CC
    Don't beat yourself up. As long as the CC doesn't exceed .5 or really spike on you, you should be fine. Assuming there were no testing irregularities, your water may just be working to process some stuff via oxidation, and you just happened to grab a sample at that particular time. Good thing is you know what to look for.
    30,421
    The rule of thumb is to treat .5 CC as if it were ZERO.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    I am in the process of doing a OCLT test, and my FC was at 4, and CC was 1., or 1.5 because I took two tests. FC was at 7.5 this afternoon. I am at a complete loss, as I have tested and retested since I opened a month ago, and my numbers have been so good. I could go on about how many times I have brushed, and run the manual and robot but I wont.
    Do I wait until morning and see what my numbers are, or do I go ahead and dump the gallon and half of bleach in tonight. I don't have enough for a full SLAM on hand, but maybe enough to get started?
    I guess I will need to use the manual vacuum for this, not the robot?
    Last but not least.........I AM STUNNED!!!
    Mark
    Jun 2014
    15,149
    Good morning. I didn't see your last post until this morning. Hopefully your OCLT went fine. If not, you probably know what needs to be done from here. If you did pass but your CCs still seem elevated, please post a full set of results and we'll see what we can do.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    OK, I must be in the twilight zone! I lost sleep over this last night......HA! I am going to post the numbers now, and I promise I was not drinking last night either, at least not until the test was over.
    Todays numbers
    FC: 7
    CC: 0.5
    PH: 7.5
    TA: 70
    CH: 75
    CYA: 70 (Tested yesterday)
    Salt: 3300
    Water temp: 71
    I have no idea what is going on. I hold my reagents vertical and watch the drops carefully so they are the same size. I am at a loss to explain last nights numbers. Pool looks as good as it ever has, you can easily count the holes in the main drains. Good thing I didn't start dumping in the bleach I had on hand last night!!!
    Mark
    Jun 2014
    15,149
    Those numbers look very good. You're ready to start your weekend. It's Happy Hour somewhere in this world.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Quote Originally Posted by Texas Splash View Post
    It may happy hour here this morning!!!! I don't know how to explain last nights test though!
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    I'm sorry if I'm beating a dead horse here. This really has me concerned. Is it possible that my test cylinders were contaminated? I rinse after every use, and dry them with a paper towel before returning them to the box. Should I clean them somehow? If so.......with what?
    Mark
    Jun 2014
    15,149
    They are fairly new right? Probably fine. But whenever those tubes look to appear hazy, coated, or dirty, simply clean with some bleach. Let it sit for a couple minutes and that should do the trick to break-up any residue.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Six months old and look brand new. I hope I just made a mistake last night, but I sure don't know what it would have been.
    Mark
    Jun 2014
    15,149
    Trust this morning's test. It's the latest reading and you were probably sober at the time. You're getting to know your pool very well ... the clarity, how much FC it uses, and how much chemicals you typically put in. But from time-to-time, something will change and you'll see it. That's what TFP is all about - you being in control. For now, it doesn't appear you have any worries. When/if you do, you'll know it right away and know from your TFP learning what to do.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Thanks Pat!
    Mark
