Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Thinking of adding a Liquidator or Stenner
    Dec 2014
    Cypress, Texas
    200
    Any feedback on the Liquidator?
    I see many people here setting up a Stenner Pump, but the Liquidator looks like it would be easier to install and probably cheaper as well. Any reason why I shouldn't use a Liquidator??
    Thanks!
    Also now looking at Stenner Pump
    2016 Build: 32x8 Gunite, 6,700 gallon IG pool including 6x8 spa and 6x8 tanning ledge w/ 2 bubblers. 32' raised wall with two sheer descent water features. Travertine Coping w/ split faced Travertine on raised wall face. 2HP VS Jandy pump, 400k heater, Rainbow Chlorinator, 4 Colored LED Lights. 459sqft spray deck plus. IAqualink remote, Polarus 9350 Robot Cleaner.
    JoyfulNoise's Avatar
    May 2015
    13,173
    Re: Thinking of adding a Liquidator
    Quote Originally Posted by Mamiamjo View Post
    Thanks!
    The Liquidator is cheaper but it is sometimes harder to get setup. The Liquidator relies on passive flow to control the chlorine injection. It uses the pressure differential created by the pool pump and two internal float valves to set the flow rate of diluted chlorine into the system. Variations in system pressure can cause variations in this dosing. There are also issues in some areas with calcium flakes forming on the surface of the liquidator solution tank that can clog up the lines. I think a lot of people like Stenner pumps because they can be easily automated on a schedule and their dosing is, for the most part, independent of system pressure.
    Matt
    Dec 2014
    Cypress, Texas
    200
    Thanks for your feedback Matt.
    You mention the possibility of flakes forming that could clog up the lines. Maybe you can help me understand what would cause that and why would it be different with a stenner pump set up?
    Thanks!
    May 2015
    13,173
    Thanks!
    Normally you add liquid chlorine to the bottom and top it off with a layer of water. The water and LC stay mostly separated but the water layer has a high concentration of chlorine in it and has high pH. The flakes are caused by calcium hardness reacting with the high pH to form calcium carbonate scale. The scale can get lodged into the float valves and cause problems.
    Matt
    Dec 2014
    Cypress, Texas
    200
    Ok so I see the potential for calcium build up, but how is the Stenner pump different then?
    Forgive my ignorance, I'm not trying to be difficult, just trying to understand
    Thanks
    May 2015
    13,173
    The Stenner pump is direct injection of LC into the return line of your pool. The tank holds the full strength LC. At no point is the LC exposed to any CH except at the point of injection. Therefore there is no way for calcium scale to form as long as the LC tank and tubing remain free of water.
    Matt
    Apr 2013
    Sacramento, CA
    2,769
    As a former Liquidator owner the three main issues are:
    1. They don't play well with variable speed pumps. The Liquidator relies on passive suction to work -- if the pumps working its working. So the more your system is on and the greater volume the more chlorine. A VS pump on low speed barely provides enough suction for the Liquidator to work. If anything goes wrong - it looks fine but there is no flow.
    2. They don't play well with solar. Say you balance the chlorine based on low speed, if the solar kicks in you are dumping excessive amounts of chlorine in the pool. And since the solar is temperature sensitive you can never be sure exactly sure how much chlorine you will use on any given day in the summer. All adjustments are a guesstamation. With a Stenner you can be very close with the big variable of sunlight.
    3. The dreaded white stuff. You never see it. Then it comes. You drain your tank and clean the feed lines with vinegar every three months. It comes back. It keeps coming back. You go away for a week and there is no chlorine in the pool. Agggguhgh!!!!! With a Steener I clean my injection port of salt twice a year when I clean my filter.
    Dec 2014
    Cypress, Texas
    200
    OK, so you convinced me, maybe I should consider a Stenner pump, but I must admit that it still looks a lot more complicated- Buying the pump, finding a tank, deciding on a timer and figuring out how to hook it up to the controller etc.
    Can anyone tell me the easiest way to purchase and install everything I need?
    Thanks!
    Apr 2013
    Sacramento, CA
    2,769
    lokewell.com
    get a 15 gallon grey tank and a 100psi 10 gallons per day fixed rate pump.
    Have them set up an outlet controlled by the iaqualink relays.
    Search around there are a bunch of threads on how to set up a steener with details.
    Dec 2014
    Cypress, Texas
    200
    Re: Thinking of adding a Liquidator or Stenner
    Ok I found the following Stenner Pump items online...
    Stenner 85MPHP17 100PSI (is this a good one?) for $208
    Gray 15gal tank $114
    Rain Cover $12
    What else would I need to get?
    Dec 2015
    Newington, Connecticut
    113
    I've done a lot of research on the liquidator and chose to try it out. Many people I talked to have had no issues and love the liquidator. Putting mine in operation tomorrow and will see how it goes this summer. If it doesn't. Ill move on.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    Rain Cover $12
    You need way to connect the check valve to your return line. Some install a Tee with a 1/2" thread. Others make their own threaded opening into the existing pvc pipe. To control the Stenner you can use the Woods electronic timer or integrate it with your Aquilink.
    Jay--Metro NYC
    35K gal, in-ground, free-form, pebble finish, 2 skimmers, 3 returns, autofill. No spa, no features. Partial shade.
    Pentair C&C cartridge filter (400 sq in), Pentair VS pump, Pentair 140 btu heat pump, Triton Plus Robo-cleaner; Stenner with 55 gal bleach cistern. TFT 100 test kit.
    Mar 2015
    Sugar Land , TX
    424
    There is a guy who parks his truck up in Tomball near 2920 and Boudraex in. I paid $20 for a used 15 gallon blue tank. I can not remember exactly the corner but he is always there.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    Or you can find used food-grade HDPE tanks on Craigs List. I paid $30 or $35 for my 55 gallon drum. Rinsed it out, good to go.
    Jay--Metro NYC
    Dec 2014
    Cypress, Texas
    200
    Quote Originally Posted by fauxQ View Post
    I know I can get another brand tank for less, just want to make sure I know what all to buy. I'm not sure how to tie into the Aqua Link but you mentioned the Woods electronic timer, I see a bunch of them online. Which would you recommend??
    Thanks
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    Most people get this for a timer:
    http://www.amazon.com/dp/B006LYHG42/...l_23l195329o_b
    The trick is to set it so that you are sure that your circulation pump will be running while the Stenner is active. Not that hard to manage for most pump schedules.
    The tank really depends on your situation (daily FC use, equipment pad space, etc). You have a small pool volume and could get by with a relatively small reservoir. Use pool math to calculate how much bleach you'd need to inject to achieve 2-3 ppm FC each day and then figure how often you want to refill. The only caveat is that bleach will degrade at higher temps, so unless you can protect your bleach tank from the sun, it may not make much sense to have a tank that holds a 3-month supply of bleach. Chem geek has worked out the relationship between temperature and bleach stability:
    http://www.troublefreepool.com/threa...perature/page2
    Post #23.
    If you can manage the install, it seems to me that the Stenner FC delivery system is the most bullet proof system out there. Good luck.
    Jay--Metro NYC
    Dec 2014
    Cypress, Texas
    200
    Rain Cover $12
    OK I'm ready to pull the trigger, but still have questions regarding the equipment...
    1) I've looked at both the 45MPHP and the 85MPHP Stenner Pumps, (Fixed Rate, 100 PSI, 10GPD). They appear to be charging the same$, so what is the difference, which would be better?
    2) Which tube do I need? 1/4 or 3/8?
    Thanks for your help!
    Apr 2015
    South Central PA
    297
    I think the 45 series operates at a lower speed (rpm). I don't think the 85 has a 10 gpd....it has a 5,17, and 40. Did you make sure the run time will be OK for your size pool when coupled with the selected Stenner? See the post:
    How long to run Stenner pump?
    Better to check now that end up with one that's not quite right, though you could make pretty much any work if needed. The only difference between the 45 series 3gpd, 10gpd and 20gpd is the internal tube size. This tube is a maintenance item and could be changed to create the any of the 3 gpd flow.
    For your size pool, 1/4 should be fine.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Dec 2014
    Cypress, Texas
    200
    Quote Originally Posted by 440dodge440 View Post
    You are correct, the 85 has a 17 GPD, the 45 Series has the 10GPD pump. It seems that either one would work for me as I would need about 32 oz of chlorine dispensed. Obviously the model 85 would do it in less time, but other than that, what would the difference be between the two pumps?
  20. Back To Top    #20
    Apr 2015
    South Central PA
    297
    I don't think there is a difference other than the speed the pump runs. I asked about this in the past and if I remember correctly that's the answer I got. Hopefully someone will come along to confirm or correct if needed. I went with the 45- I figured the slower feed would be better for the equipment.
