Results 1 to 14 of 14
Thread: Just got my TF100 XL kit. Confused.
    Apr 2016
    Loxahatchee, FL
    12
    Hi everyone,
    Just received my test kit and I wanted to an initial test of everything, but on the Pool school it says to add R0870. I don't have that in my kit. The closest I have is R0871. Is this the same thing? I have never done anything like this before. Just want to make sure I am doing it right.
    Thanks!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Just got my TF100 XL kit. Confused.
    Welcome Faust, and no it isn't.
    Double check, and if you are missing it for sure, they will take good care of you immediately at TFTestKits. Just let them know, and it will be resolved quickly.
    Essential Links:
    Apr 2016
    Loxahatchee, FL
    12
    Quote Originally Posted by Patrick_B View Post
    Found it. Small bottle.
    Here are my initial results:
    FC 0
    PH 7.5
    CC 0
    Calcium 725ppm
    TA 300
    CYA 58
    Finally got frustrated that I keep getting algae after going to the pool store and found this site. Great stuff in here. Hoping I can get some advice on how bad off I am.
    I am having trouble with the pool math. Do I add my results in the left or right column? When I am done, I click on Calculate, right? Nothing seems to be calculating. A tip here would be great!
    And since I know you guys like pics, here is one of my pool. Windy day in South Florida!
    Hopefully my signature shows up now.
    18500 gallon oval pool. Filter: Hayward cartridge filter. Model: C12002. Pump: Hayward 1 speed (I think) 1.5hp Max-Flo XL Pump. Model: C48D43AO4. TFT100 test kit.
    triptyx's Avatar
    Apr 2016
    1,438
    Set your pool size. Scroll to the bottom and check your pool type (I think it defaults to plaster so from the looks of your picture you're good there) and make sure your chlorination method is correct.
    Put your results on the left column fields. Put your targets (what you want the numbers to be) on the right side. The form should auto-update, but you can click "calculate" if you want to make sure.
    Voila!
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jan 2014
    Buckeye AZ
    807
    If you have 0 FC, that means the pool sample didn't turn pink at all when you first added the powder, right?
    For pool math, you put your pool volume in (no commas).
    Go to the bottom and put plaster as your type, and set the reference to troublefreepool.com
    put your readings in the left column. The right column is the "target column", and this is set initially when you select TFP as I said above. You can change the target if you want, in some scenarios, but not for now.
    The information to the right of the two columns will update with what you need to add to the pool. How much chlorine (depending on what type you opt for), how much acid, if needed, etc.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    38,260
    Put your tested values on the left and your desired values on the right. It should auto update and not even require you to push to calculate button I think.
    38,260
    The high ph and ta are going to require you to keep tight control on your pH to avoid calcium scaling. Luckily your cya looks reasonable and you just need to maintain proper levels of chlorine although you may need to follow the slam process first
    Apr 2016
    Loxahatchee, FL
    12
    That's what I'm wondering. Should I just start adding bleach and see what happens?
    38,260
    Well the only way to lower the calcium is to replace water. If you are not going to do that then you do need to start adding chlorine..
    Apr 2016
    Loxahatchee, FL
    12
    Quote Originally Posted by BuckeyeChris View Post
    Right.
    Jan 2012
    'burbs of Augusta, Georgia
    7,287
    Wow, for a pool that tests at zero chlorine, its looking pretty clear!
    To use PoolMath you need to first put your pool size in gallons at the top, then scroll down to the bottom yellow area "Goal Levels" and input that your primary source of chlorine is...what?? Do you have a SWG or use liquid chlorine (aka bleach) or what?? Then you want to select that you want to use Troublefreepool.com levels, and what your pool surface is (plaster, vinyl or fiberglass). All these parameters have affect on the suggested levels of each chemistry test, as you'll see as a range in each test level. Input your own test results in the left hand "Now" column, and using the suggested levels pick a goal level to type in to the "Target" box. Fill it all out and hit "Calculate" and you'll see suggested fixes (if you need them).
    Obviously the first thing for you is going to be getting chlorine in to that water! Your CYA is 60 (round up or down, no middle ground) and your chlorine should never drop below 5 with a goal of 7 (to allow for daily drop so you won't go under 5). Your TA is ridiculously high, so I question that? Your pH is fine, but if you can lower it to 7.0-7.2 repeatedly with muriatic acid, it will drag the TA down with it over time. Then you just use a fountain or method of aeration to raise the pH again. Next your calcium is really high too, but being in FL you can lower that over time with the repeated rains you get that require small drains to keep pool from overflowing. Stop using calcium products in your pool (if you are) to avoid developing calcium scale.
    Apr 2016
    Loxahatchee, FL
    12
    Quote Originally Posted by YippeeSkippy View Post
    Ok, PoolMath works now. Thank you! I did add 30 drops for the TA test and I have had recurring algae problems. I will monitor it. Adding bleach now.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Once you get comfortable with everything, you may want to perform an OCLT Pool School - Perform the Overnight FC Loss Test (OCLT) to see if you need to SLAM.
    Apr 2016
    Loxahatchee, FL
    12
    I will definitely be doing that.
