Thread: Gauge won't drop to zero
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    When I turn my pump off, the gauge drops from 25psi to 10 psi.
    Should I get a new gauge? I thought the glycol filled one I purchased last season would still be good!
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Gauge won't drop to zero
    It should. Did you snip the tip off the little black insert on the top of the guage? If not, you might try that and see if it drops it to Zero. It's a pressure equalizer, and doing this might fix it.
    Essential Links:
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,529
    Pull open the little doo-dad on the top to equalize the pressure.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If that does not work, unscrew it and see if the pipe stem is clogged
    38,303
    Weirdly I noticed mine was only going down to about 2 PSI. I pulled the black rubber stopper off and the pressure reading actually went up which was not expected. So I shoved the stopper back on and the pressure seemed to go down closer to 0 and I called it good enough
