Results 1 to 7 of 7
Thread: Good morning all
    Apr 2016
    Clearwater,Fl.
    2
    Cool Good morning all
    I'm new to this forum and would like to give you some info on my pool. I have a year old above ground 15x30x 54 " depth. 2 HP pump and a cartridge filter system. I have used Pristine Blue since starting pool. No issues there. I use a Polaris 65 sweep for cleaning. I live in Central Florida and no tree shade for pool. Temp in summer 88 - 92 degrees. My question today is , How often should you have to add water before you consider having a possible leak ? Thank you for any info in my climate.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Good morning all
    Welcome, if you suspect a leak you can perform a bucket test to confirm it Pool School - Leak Detection
    Jun 2014
    15,008
    Welcome! It would also be helpful if you would please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    Water loss depends on temperature, humidity, and wind. Where I live, the hot dry Santa Ana winds can strip half an inch out of my pool in a day. I suspect low humidity is not a problem in Florida, but winds could be. A bucket test will tell.
    Casey's Avatar
    SW PA
    10,423
    Welcome to TFP!
    30,403
    It's a little dry in Florida now so as much as a half inch daily evaporation might be expected but certainly no more than that. 1/4 inch is pretty normal
    Apr 2016
    Clearwater,Fl.
    2
    Thank you for the advice
    Thank you for the Welcome
    Thank you
    Thomterriffic , 15 X 30 X 54 inches deep above ground oval. 2 HP pump with a cartridge filter. Pristine Blue used since start in 6/15/2015.
