Thread: FC level vs PPM on bleach bottle
    Aug 2014
    Litchfield, CT
    7
    Can someone explain the different between the FC level and the warning on the bottle of bleach to not swim if bleach if more than 3ppm?
    I am keeping my FC level at the recommend level and have not had any issues, but my husband is concerned with the bleach label stating that we should not swim if the bleach is higher than 3ppm.
    Thank you.
    Accounting MaMa
    21,500 gallons, IG, 18x36 vinyl, Pentair CCP420 Cartridge filter, Pentair IntellifloFX VS Pump, Pentair Ultra temp Heat Pump 140,000 BTU,
    Interfab G-Force 2 Slide, Pentair GloBright LED Lights, Installed 8/18/14,TF-100 Test Kit
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: FC level vs PPM on bleach bottle
    The container does not take into consideration the amount of CYA that is in a pool. The higher the cya the more fc you need to sanitize your water as some is locked up by cya itself.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    The 3 ppm is for water with no CYA in it. The active actual OCL- concentration is lower with some stabilizer (CYA). 2 FC with no stabilizer will bleach swimsuits rather quickly. But I've swam in water with 20 FC and 200 CYA withe no problem, eyes open underwater even.
    This scholarly thread has some graphs. Note the graduations are logaritmic. Pool Water Chemistry
