Thread: Learn me about Backwashing
    May 2014
    Virginia Beach
    52
    Stupid question for all ye experts -
    It appears to me that there is a certain black-magic regarding DE and backwashing. In other words, how much DE should I add following backwash?
    My initial fill is 7 scoops. After a few hours of runtime, the filter was clogged and I backwash for approx 30 seconds. The sight glass went from brown to white to clear and I stopped. I added two scoops and ran the filter for a few hours until it clogged and repeated the process, adding 2 scoops again.
    Is that correct or should I add more DE?? The pool is now clear and the filter output strong.
    Many thanks!!
    8-10,000 Gallon In Ground Pleasure Pond. Probably 15 (?) years old.
    Recently new Groovy Blue Vinyl liner. Newer Hayward DE filter and Aqua-Rite SWG system.
    Eight Passive Solar Heating Panels. 1HP single speed motor.
    Virginia Beach, VA.
    Apr 2015
    South Central PA
    297
    Re: Learn me about Backwashing
    Good question, I'd like to know the answer as well. One thing- consider going Backwash-Rinse-Backwash-Rinse-Backwash. I noticed if I do this, it takes several backwashes before I get non-green water.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Each time you backwash you should recharge with 80% of the fresh fill as explained in Pool School - Maintenance and Cleaning of Pool Filters.
    There can be problems if it doesn't all get washed off the grids. You don't want it to end up like this inside
    Now that the water is clear, it would probably be a good time to do a full teardown and cleaning, and after you recharge with the full amount of DE, get a baseline clean pressure reading. Then in the future you will know when pressure climbs 25%.DE Filter Cleaning Tutorial
    May 2014
    Virginia Beach
    52
    Richard,
    MANY thanks. I don't know how I missed that when reading. Either that or my CRS is advancing much faster than my ear and nose hair are growing. I will follow your advice and clean the grids and re-DE.
    I'll also read the link you posted. Thank you again for your advice.
    Virginia Beach, VA.
