Thread: Plumbing Question
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Plumbing Question
    I been wondering what these pipes are for outside my pool deck ever since I have been here. I never seen anything come out of them since they are both capped I'm guessing the builder put them in if you wanted to maybe add a different type system in the future?
    Could they be to the floor drains since they are inline with them to drain the whole pool out? I tried to get water to come out of them last year when I moved in by turning the drain levers but nothing happened. So I put them back where they was and left well enough alone.
    I'm hoping you guys can give me a clue what they are for.I hate not know stuff since Im a new pool owner I guess I should know.Thanks for all your help in the past.
    Hope the pic shows here..
    20160421_091415.jpg Photo by sarge173 | Photobucket
    6100 gal. In ground pool,1HP Pentair Superflo pump, 100 sq. ft. Cartridge filter , 3" tab dispenser, Aqua-Cal heat pump system ,Baracuda MX8 cleaner, in a Birdcage,Taylor K-2006 complete FAS-DPD chlorine kit.
    "Remember Folks Freedom Isn't FREE !!!"
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Re: Plumbing Question
    Lets try this for the picture:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    My guess is that they are wellpoints that penetrate down lower than your pool is deep. They hooked pumps to them to draw out ground water while working in the hole. Once the shell is hardened and full of water, it won't float, so they're done with them. If ever you need to empty the pool for some kind of work, they'll probably come in handy again.
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Thanks...That makes sense to me. I was told to never drain the pool more than half way when I moved in here, that it could pop out of the ground from the low water table here.
    If anybody else has these around there pool let me know.
    Thanks Again Richard
