Thread: New pool construction
    Lophat's Avatar
    Apr 2016
    Richmond, BC, Canada
    16
    Hello all,
    We are in the midst of our backyard overhaul and my question is in regards to ground prep for our upcoming 12 x 24 Vogue pool. While I will be removing the high areas to get it level, our concrete guy has offered to compact the area and put down a crushed road base and compact that and level it as well. This is the same base that will be under our concrete. Should I have any concerns going this route? Any advice is appreciated! There will still be sand inside the pool and a insulated pad that the liner will sit on.
    thanks!
    Atrium 12' x 23' AG Resin salt water pool w/ wall and ground insulation, 7300 gallons, Pentair Intelliflo VS pump, IC20 IECG, Clean and Clear 200 filter, Mastertemp 125 Gas heater and two Maytonics solar panels, Polaris AG pool cleaner. Easytouch 4, and Intellichem(undecided at this moment). All new Trex decking and patios to boot!
    Casey's Avatar
    SW PA
    10,444
    Re: New pool construction
    Sounds like a plan. Just double check the leveling when he's done.
