Results 1 to 10 of 10
Thread: Just found this forum and am quite new to the pol ownership
    Apr 2016
    Ada/Mi
    4
    Question Just found this forum and am quite new to the pol ownership
    Hi,
    I'm from Sweden but live in Michigan since 10 years. Last summer we installed our pool and this year we are looking forward to enjoy a full summer with our pool. I set out early to learn about the pool chemistry and find it troubling. For example this year we just opened the pool and since it was first time I had the pool company come out and do it for me. Everything has been going well and pool is looking fantastic. Still not to warm here in Michigan last few days but I've been monotoring my settings and checked Fc and TC morning and night to see if I could figure out the correct percentage for my chlorinator.
    Here is what has happened since Monday morning without any swimmers during this whole period with exception of 2 small frogs:
    4/18 Chlorinator 70%:
    AM;
    FC=3.69
    TC=3.80
    PM;
    FC=4.68
    TC=4.68
    4/19 Chlorinator 70%:
    AM;
    FC=6.44
    TC=6.44
    At this point I decided to lower my percentage to 60%on chlorinator.
    4/20 PM:
    FC=7.79
    TC=8.73
    So now all of a sudden I have too high level of chlorine no one has been using the pool and I need to shock it??
    I do not understand what I need to do to maintain a stable pool. Please help.
    Heated inground salt chlorinated 18'x36' 26,000 gallons, vinyl. Pentair continues pump.
    38,547
    Re: Just found this forum and am quite new to the pol ownership
    Welcome to TFP!!!
    Why do you think you need to "shock" it? BTW, we do not use that word around here
    What you need to do is turn down the SWG because it is generating too much FC.
    What are you testing with?
    Have you discovered Pool School yet? Start with these to learn how to manage your pool:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    Water Balance for SWGs
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Welcome to TFP!
    What is your CYA level? It is safe to swim with FC up to shock level for your CYA.
    Casey's Avatar
    SW PA
    10,461
    Welcome to TFP.
    Apr 2016
    Ada/Mi
    4
    Hi,
    Thanks for reading my post. Using Color Q7, Lamott I believe. Well I was under the impression that my CC could not be over .4ppm?
    Today FC=9.89 I now changed Chlorinator to 20%
    TC=reads Hi
    CYA=38
    CH=135
    ALK=103
    PH=7.4
    38,547
    We do not recommend the use of the ColorQ unfortunately. It has limitations (like FC < 10ppm) and often reports wildly differing results. A quick search of the forum will bring up many threads, often with frustrated owners that throw them away.
    Apr 2016
    Ada/Mi
    4
    Well it is important that you measure in good light and have fresh reagents. I have been pretty satisfied with it and compared it with different pool stores readings and am getting same results basically. So that is not the problem I'm having. But thanks for your advice.
    I was more curious to know if the threshold of allowed CC is the same no matter what FC level?
    38,547
    Well, we do not trust pool store testing either
    We typically say that a CC of no more than 1 drop is acceptable. This is usually 0.5ppm. But in reality, the CC should typically be much lower than that.
    I certainly hope you do not get algae, because you will not be able to read the required high FC levels to clear it up with the ColorQ ... assuming you are considering learning and using our methods or course
    Apr 2016
    Ada/Mi
    4
    Ok, well I can see that being a problem when it stops reading at 10. But I have a real hard time with color matching so I was thrilled when I found this device. What do you use?
    38,547
    Well that's the beauty of the test kits that we recommend. Only the pH is requires color matching the rest you just count a drop until a color changes.
    See the test kits Link in my signature for the comparison page of test kits that we recommend.
