Results 1 to 9 of 9
Thread: Vacuuming and dirty water coming through return jets
    May 2014
    Muncie, Indiana
    30
    I have a question. Opened up my pool on Sunday and vacuumed to wasted pretty green pool. Started the slam process and thought I would try to vacuum the pool on recirculate although still can see bottom in deep end. I noticed dirty water coming through return jets when I vacuumed in the deep end. Lots of leaves worms ect sucked up in vacuum head. Should I still vacuum to waste? Why is the dirt coming through the return ? Sand is only one year old. Thanks
    12k gallon inground pool with vinyl liner. Sandfilter, hayward 1.5 hp pool pump. Pool is approx 15 yrs.old. Liner is four years old. TF100 testing kit.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Vacuuming and dirty water coming through return jets
    Recirculate bypasses the filter entirely. Dip out everything you can, then either vac to waste or normal filtering setting.
    May 2014
    Muncie, Indiana
    30
    But if you vacuum to recirculate isn't that going to through all the dead algae into pool?
    I was vacuuming on filtered setting then when I hit a big glob of leaves ect that's when I noticed the return water was bad
    Aug 2014
    Northern IL
    4,615
    Not sure I get a you are saying, but like Woodyp said, if you vacuum while recirculating, you are just putting all the gunk back in your pool.
    30,432
    If you are on "filter" setting and getting dirty water through the return jets, you're filter may be clogged. Have you cleaned/backwashed it?
    May 2014
    Muncie, Indiana
    30
    Yes I back washed it and it was fine but then after awhile it began the dirty water thing again when I got to into the thick leaves ect. I think I need to vacuum on waste for awhile
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    possibly check your spider gasket when you get a moment, someone else just had similar issue and the gasket was bad.
    Dolphin E10 Cleaning Robot.
    Jul 2013
    North Canton, OH
    192
    can sand filters "channel" and allow dirty water to get through?
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Apr 2010
    East Texas
    9,659
    They absolutely can.....but I don't think to the degree the OP stated.
