Thread: Chemical ID needed.
    Apr 2016
    Stevens Point WI
    2
    Chemical ID needed.
    We recently took over a hotel, we're sorting through chemicals and found a jug that we're not sure what is it. It's a black powder type and turns the water purple. The jug is plastic and says Oxidizer 5.1 with a yellow lable. What might this be and used for?
    Thanks for any help.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Chemical ID needed.
    Welcome to TFP!
    It sounds like Potassium Permangate, but I'm not sure that's what it is. I've only used it to regenerate Iron "filters" or exchangers for Iron removal. Why did you put it in the pool?
    Essential Links:
    Donldson's Avatar
    NW Ohio
    2,887
    I agree with Patrick, that is what it sounds like. I use it in my green sand filter to reduce iron and hydrogen sulfide. Can't think of a situation where it would be added directly to a pool.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2016
    Stevens Point WI
    2
    Thanks for the information guys!!
    I didn't add it into the pool at all. I got a bucket of pool water and put a small amount of it in there and that's how I found out about the water turning colors. If I don't know what something is or does I don't add it since this is a commercial pool.
    30,408
    Don't use it. You don't need it in your pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by mlk77 View Post
    Oh, ok, good deal then! Whew....
    Essential Links:
