Thread: Diamond Brite flawed application? Opinions please
    Oct 2015
    baton rouge
    41
    Hello,
    Late last fall I had my pool built. At handover I was told to brush it down daily for a month and check chems. I did both religiously, and kept chems dead on perfect. I soon had to cover the pool as winter came on but still monitored the chems weekly and did my best to keep pool clean from leaves and such. The weather here rarely goes below 50F
    Finally the cover came off this week, cleaned it up and its sparkling blue and gorgeous. But now with the cover finally off, I notice lots of markings in the diamond brite. This is the same diamond brite I had at a previous home in the past, but I never remember seeing this before, so I am now wondering if it was applied properly and if there might be long term problems.
    At first I thought it might be just dirt or minor distortions, but after getting in there and scrubbing, it became apparent that these are permanent and not going anywhere.
    The pictures attached are untouched. It would actually be far more apparent if I would have waited later in the day when the sun was not directly on top, but you will get the idea. I circled the areas in question.
    Hoping someone can give an opinion based on their experience. I paid a lot extra for Diamond Brite so I was expecting great results. Its not the end of the world but it does bother me looking down at this.
    Thanks in advance.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Diamond Brite flawed application? Opinions please
    This thread might be helpful, Diagnosing Pool Plaster Problems
    Oct 2015
    baton rouge
    41
    Quote Originally Posted by pooldv View Post
    Thanks for the link.
    I read that thread and I couldnt really match my problems to anything on that list except procedure.
    I'm far more interested in hearing from others that had a similar color with Diamondbrite done, what their results were and where this falls within the "quality zone".
    Casey's Avatar
    SW PA
    10,438
    That looks like dung! WOW
