Results 1 to 10 of 10
Thread: Pool heaters
    Chisek's Avatar
    Apr 2016
    Homer Glen, IL
    13
    Pool heaters
    Can anyone help me decide which pool heater to get & how many btu's should I get?
    My pool is about 35,000 gallons with about a 720' surface area. I am replacing a 25,000BTU Hayward which looks to be 20 years old (we just bought the house.) Are haywards still that reliable or should I be looking at a different manufacture?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Re: Pool heaters
    did you mean 250,0000 btu?
    Hayward is notoriously unreliable (especially the newer models) Lots of talk about that if you search the forum.
    Raypak seems to be the most reliable.
    The Raypak R406A looks like a good option if you have natural gas.
    Dolphin E10 Cleaning Robot.
    Jul 2012
    Chicago, IL
    356
    Re: Pool heaters
    Raypak definitely seems to be the favorite on these forums, I just got the 406A last July and love it. With a pool that size you want to get the highest BTUs possible, mine heats my 21,000 gallon pool about 2 degrees per hour.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    JoyfulNoise's Avatar
    May 2015
    13,193
    Re: Pool heaters
    We have a couple of pool pros (in the industry, or ITI) on this site and they all seem to recommend Raypack as the hands down winner (simplicity of design, maintenance is easier and less costly, units are highly reliable and well-built).
    For your size pool I think you'll need a 400kBTU/Hr unit. HOWEVER, check your gas line and meter setup. If you're upgrading by that many BTUs, the gas company will likely need to install a bigger meter to provide sufficient supply.
    Matt
    Chisek's Avatar
    Apr 2016
    Homer Glen, IL
    13
    Re: Pool heaters
    Quote Originally Posted by borjis View Post
    Oops. Yes, I did mean 250,000. Thanks for the help. 1st time owning an in ground pool. I was looking around online & all heaters seemed to have mixed reviews. I was leaning towards the Haward just because the one I'm replacing seemed to last a long time. I will look at the Raypak now.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool heaters
    Welcome to TFP,
    No doubt you'll need the 400 series with that size of pool and no less. Raypak, and Rheem are one in the same too just FYI.
    Essential Links:
    Chisek's Avatar
    Apr 2016
    Homer Glen, IL
    13
    Re: Pool heaters
    Going with a Raypak heater. Now the only question I have is, should I order a Millivolt or a digital heater? What are the pros & cons of each?
    May 2013
    New Jersey
    64
    Re: Pool heaters
    This as an older thread I just saw which may still apply. I am about to replace a millivolt Hayward heater which was just a constant PIA. Every time it started without fussing of some kind I was thrilled. It runs off of the energy of the pilot light (wasting gas all day), and there is so little power off the bat that any issue with any part and it just does nothing. Total PIA.
    Bernie
    Bernie
    20,000 Gallon (16 x 32), IN ground, Vinyl Pool
    Hayward Single Speed 1-1/5 Hp Pump - 3/4 HP "Booster" (?) Polaris 280 Vacuum
    48 Sq Ft, 96 GPM, Diatomaceous Earth Filter
    Pool is approximately 15+ years old- Newer than 1985
    Hayward 300,000 BTU H300MV Heater (Milli-Volt UGH!!)
    May 2016
    Toronto
    129
    Re: Pool heaters
    35,000 gallons and you had a 250,000 BTU heater? How did that work out? Does not seem like its enough BTU's.
    I just bought a 206,000 BTU Raypak. My pool is 20,000 gallons though, and even that I was told was not enough from the pool store????
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    Re: Pool heaters
    I have a 206A and it suits me just fine. (20*40 approx. approx. 30K gls) Now if you're trying to keep it toasty in early March or late October you could have some trouble.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
