Results 1 to 15 of 15
Thread: Do you really have to pour Muriatic Acid over 2 FULL minutes?
    Apr 2016
    Youngsville, LA
    274
    I'm going to be pouring about 20 ounces of MA in my pool later today in front of return jet to lower my pH, but do I really need to pour the 20 ounces over 2 FULL minutes? That sems like an awfully long time to sit there and pour 20 ounces?
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin Nautilus Plus Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    38,284
    Re: Do you really have to pour Muriatic Acid over 2 FULL minutes?
    It is your pool and you will come up with your own routine. But that is certainly a safe recommendation.
    Apr 2016
    Youngsville, LA
    274
    Guess I'm just trying to figure out if it is REALLY needed to wait that long. My pool guy told me to spread it out around the perimeter of the pool. I was thinking about maybe doing half in front of one rturn jet and the other half in front the other return jet (I have 2 total).
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The issue is that the acid is far heavier than water and will tend to sink to the bottom and pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Definitely add it in front of a return with the pump on. Watch the cloud to see if it is sinking too fast.
    JoyfulNoise's Avatar
    May 2015
    13,201
    I typically pour on 20oz or so and it takes me less than 30sec in front of the deep end return. I then give the pool a brush (~10mins). That's more than sufficient to dilute and mix the acid.
    2 full minutes is overkill.
    Matt
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    i pour mine in pretty quick, probably 20 seconds. i do it right in front of my strongest return though.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2011
    Long Beach, CA
    2,786
    The faster you pour acid, more of the acid will sink to the bottom of the pool. With a slow pour over a return, more of the acid gets distributed through the water column. Watch to see how fast the acid is sinking when you add it and adjust as necessary.
    It's always best to brush the pool to help distribute the acid and prevent any damage that can happen if the acid sunk to the bottom of the pool.
    Apr 2016
    Youngsville, LA
    274
    Quote Originally Posted by ping View Post
    Good advice, I'll pour a little and see how fast it sinks and adjust from there. I don't mind pouring slowly, just didn't want to if I didn't have to. Will it really mess up the plaster on the bottom of the pool even if its a small amount like 20 ounces?
    38,284
    Just run a quick brush over the bottom and it will get well mixed quickly.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Quote Originally Posted by CajunGuy View Post
    Well, lets put it this way- I dropped a drop on my cement and now have a small hole in the surface of my pool deck. Hmmmmm... I'd say caution is in order. LOL
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Agreed.
    Essential Links:
    Jun 2011
    Long Beach, CA
    2,786
    I just reread the instructions and it says a full jug, which is 128 ounces, should take 2 minutes to pour. That is sound advice as that will dilute it enough to not cause it to sink and sit on the pool surface.
    Your 20 ounce pour should then take only 20 seconds or so.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    I just watch the swirly cloud in the water as I pour. If I see it, I slow down. Otherwise, I've never even thought of timing it.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You can also use a 5 gallon bucket to pre dilute it. Always put the water in the bucket first and add the acid to the water. Give it a light stir and pour it in.
    I've done that on evenings when it's "steaming" as it's easier on my lungs to put it in the bucket as it stops fuming right away. I always try to stay up wind of it but it's not always possible.
    Solar Blanket, Well Water, Borax Added. 68
