Thread: Lights Leaking
    Apr 2016
    Lexington
    55
    Lights Leaking
    Hi everyone! You guys helped me get this terrible swamp pool all cleared up & ready to list the house for sale. WELL, now I have a leak! I've read through a lot of articles & posts & used food coloring to check and I believe it's coming from both of these Pentair lights. I called the pool store & was advised to use underwater epoxy. Anyone know the where I can find instructions on how to fix it? Thank you!
    Photo- Pool light | Flickr - Photo Sharing!
    Lexington, NC, 24 ft Above Ground, Vinyl Liner, Hayward Sand Filter, Hayward 1 HP Pump, Tablet Chlorinator (use Tricholr), Taylor K-2006 test kit, County water.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Lights Leaking
    Ok, I'm going to suggest you commit a act of violence upon the &^*^*&^ at the pool store that gave you that "advice."
    Is the leak around the edge of the lights? If so you need to read the installation manual twice, remove the lights and replace them with new gaskets. Follow the instructions to the letter. You can buy the gaskets at the pool store or better yet an online store that will take your call like Sunplay.
    If its the light itself I believe for that type of light its replace the light. I'm not seeing what one would epoxy here.
    Apr 2016
    Lexington
    55
    Re: Lights Leaking
    Quote Originally Posted by gwegan View Post
    SEE! That's why I come HERE for advise I will dig around the internet some more for a manual. Thank you!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Lights Leaking
    And we like you coming here--------I can see your smile from here! LOL
    Kim
    Apr 2016
    Lexington
    55
    Re: Lights Leaking
    Yep!
    Apr 2016
    Lexington
    55
    Re: Lights Leaking
    Can anyone identify these lights by the photo? I'm guessing they are Pentair since the unit is, but I'm not sure?
    Could be these? http://www.pentairpool.com/pdfs/GloB...orLEDEngOM.pdf
    I'm not sure?
